Logitech M505 Black Wireless Mouse - 2.4Ghz USB Wireless Receiver
Wireless Mouse M505
Quicklinx: 65S1WS00 Mfr#: 910-001324
A combination of form and features help you get more done, more comfortably, in more places.
Get more of what you need to get more done, more comfortably and more battery life. The ability to use it in more places! It is a more convenient wireless receiver and a more comfortable shape.
15-month battery life
The long battery life virtually eliminates the hassle of changing batteries. The On/Off button saves power, while an indicator light eliminates surprises. Big on battery life? We are, too.
Laser precision
Laser precision means you'll enjoy smoother tracking on just about any surface.
More places
You'll get your cursor right where you want it to be with smooth, precise laser tracking.
Logitech® Unifying receiver
The tiny receiver stays in your notebook. Plus, you can easily add a compatible wireless mouse or keyboard--without the hassle of multiple USB receivers.
Logitech® Advanced 2.4 GHz wireless
You get the reliability of a cord with cordless convenience and freedom--fast data transmission and virtually no delays or dropouts.
Ergonomic design
The sculpted, ambidextrous design, with soft rubber grips, feels good in either hand--even after long hours of use. And it's portable for comfort on the go.Change the cursor speed? Change the cursor? Change the programmable buttons?
  • 15 months of battery life
    Stay productive without battery hassles. The on/off switch helps conserve power, the smart sleep mode feature extends battery life, and an indicator light eliminates surprises.
  • Laser tracking
    You get smooth, responsive, precise cursor control - even on surfaces that typically cause problems for optical mice, such as polished or wood-grain tables.
  • Logitech unifying receiver
    The tiny wireless receiver stays in your notebook. There's no need to unplug it when you move around, so your mouse is always connected when and where you feel like using it. Plus, you can easily add a compatible keyboard or number pad, or even another mouse - without the hassle of multiple USB receivers.
  • Ergonomically designed shape with soft rubber grip
    Conforms to your hand to be naturally comfortable, yet is small enough to easily take with you.
  • Logitech advanced 2.4 GHz wireless
    You get the reliability of a cord plus cordless convenience and freedom - fast data transmission and virtually no delays or dropouts.
Logitech M505 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Laser
Scrolling wheel, soft rubber grip, on/off power switch
2 x AA type
Microsoft Windows 7, Apple MacOS X 10.4, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
Input Device
Wireless
2.4 GHz
Laser
1 x USB - 4 pin USB Type A
AA type
Installed Qty
2
Run Time (Up To)
15 months
Additional Requirements
USB port
Limited warranty - 3 years
