With hyper-fast scrolling, you control the pace. Fly through long documents and Web pages with a single flick. Or switch to click-to-click mode for precise, line-by-line navigation.
Hyper-fast scrolling
A nearly frictionless scroll wheel lets you fly through long documents and Web pages with a single flick. There's no holding you back. -
Click-to-click mode
You get the control you need for precise, line-by-line navigation of lists, slides, images, and menus. -
Scroll-mode switching
With the press of a button you can toggle between hyper-fast and click-to-click modes. The choice is yours. -
1000 dpi laser precision
With this outperforms optical mice, you will experience smoother cursor control on virtually any surface. -
Forward/Backward buttons
Do more with your mouse. Move backward or forward through Web pages or navigate your photo albums with ease. -
Plug-and-play USB
Works right out of the box-just plug it into your USB port.
- Logitech M500 - mouse - USB
- Mouse
- Connectivity Technology
- Wired - USB
- Localisation
- Western Europe
- Movement Detection Technology
- Laser
- Movement Resolution
- 1000 dpi
- Scrolling wheel, soft rubber grip
- Cables Included
- 1 x USB cable - integrated
- OS Required
- Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Localisation
- Western Europe
Input Device
- Wired
- Interface
- USB
- Laser
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- Cables Included
- Plug and Play
- Software Included
- Drivers & Utilities, Logitech SetPoint, Logitech Control Center
- OS Required
- Additional Requirements
- USB port
- Limited warranty - 3 years
