Logitech M330 Silent Plus Wireless Mouse - Black
Quicklinx: CC98WS00 Mfr#: 910-004909
Recommended Use: Mobile, Leisure, Office
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC
£24.81 ex VAT
£29.77 inc VAT
Get all your work done without missing a beat or disturbing those around you. Silent Mice have the same click feel without the click noise - over 90% noise reduction. Durable, high performance feet quietly glide over the desktop. A smooth scroll wheel completes the silent experience. Silent Mice eliminate excess noise while protecting the health and productivity of everyone. Make this your last annoying click. Your family and friends will thank you.
  • The power of silence
    Let your work speak louder than clicks. M330 Silent Plus provides advanced comfort for the right hand, excellent accuracy, long battery life, and broad compatibility-all while reducing over 90% of clicking sounds. That means full focus for you and a quieter environment for those around you
  • Less noise, more focus
    Stay focused on your work without noise distractions. Logitech's own SilentTouch Technology reduces over 90% of clicking sounds, all while ensuring the mouse performs its best. That means you can feel every single click but hear virtually nothing
  • All-day comfort
    M330 SILENT PLUS is a result of Logitech's expertise and innovative approach designing comfortable solutions for over 25 years. Its asymmetric shape is meticulously crafted to guide your right hand to a natural position, while the distinctive patterns improves touch feeling. All that allows you to work or study comfortably for hours
  • Easy navigation, precise control
    Track and scroll with excellent accuracy and precision. M330 SILENT PLUS features a rubber scroll wheel with tactile feel that gives you a controlled line-by-line scrolling experience. Logitech's high precision tracking offers next-level cursor control for great navigation on almost any surface
  • Plug & play wireless
    Setting up M330 SILENT PLUS is a snap. It works seamlessly on most OS, including Windows, macOS, and Linux. Start working in seconds by simply plugging the USB receiver into your computer or laptop. The receiver provides a strong, reliable, and flawless wireless connection within up to 10 meters (33 feet)
  • Quality you can count on
    M330 SILENT PLUS is made to be durable and reliable, it works up to 18 months without changing batteries thanks to the on/off switch button and auto-sleep power-saving mode
  • Decades of design excellence
    We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
Logitech M330 SILENT PLUS - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
6.79 cm x 10.54 cm x 3.84 cm
91 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Mechanical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, Nano wireless receiver
AA
Microsoft Windows 7 / 8 / 10 or later, Apple MacOS X 10.5 or later, Google Chrome OS, Linux Kernel 2.6
Mouse
Wireless Receiver
6.79 cm
10.54 cm
3.84 cm
91 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Mechanical
Buttons Qty
3
Movement Resolution
1000 dpi
AA
Run Time (Up To)
24 months
Recommended Use: Leisure
Recommended Use: Office
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Logitech
