Logitech M235 Wireless Mouse Red
Quicklinx: 8YV8WS00 Mfr#: 910-002496
From surfing the web to updating your Facebook - you'll be mousing on more surfaces thanks to Logitech optical. No delays, dropouts or hassles. The plug-and-forget nano-receiver keeps you connected with reliable wireless.
  • Contoured design
    Designed to keep either hand happy. Soft side grips and a comfortable shape-so you'll feel good, even after long hours of use
  • 1-year battery life
    You can go for a year without battery hassles. An On/Off switch and smart sleep mode extend battery life, while an indicator light eliminates surprises. 2
  • Logitech reliability
    You get the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty
  • Logitech Advanced Optical Tracking
    Enjoy precise clicking and pointing-on surfaces other optical mice can't handle-while navigating your favorite websites thanks to Logitech Advanced Optical Tracking
  • Logitech Unifying receiver
    The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse or keyboard-without the hassle of multiple USB receivers
  • Comfort anywhere
    The compact contoured design with soft rubber grips keeps you comfortable-even when you're on the go
  • Good-bye, tricky touchpad
    You'll enjoy smooth cursor control, precise tracking and easy text selection on the surfaces where you use your computer most
  • Six-in-one power
    The tiny Logitech Unifying receiver connects up to six Unifying-compatible devices with a powerful, reliable wireless connection (up to 25 meters)
  • Year-long battery
    You can go a full year without battery hassles. The On/Off switch helps conserve power, smart sleep mode extends battery life and an indicator light eliminates surprises
Logitech M235 - mouse - 2.4 GHz - red
Mouse
Wireless - 2.4 GHz
Red
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Battery indicator, on/off power switch
1 x AA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
Mouse
Wireless Receiver
Red
Input Device
Wireless
2.4 GHz
Optical
1 x USB - 4 pin USB Type A
AA type
Installed Qty
1
8YV8 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
