From surfing the web to updating your Facebook - you'll be mousing on more surfaces thanks to Logitech optical. No delays, dropouts or hassles. The plug-and-forget nano-receiver keeps you connected with reliable wireless.
Contoured design
Designed to keep either hand happy. Soft side grips and a comfortable shape-so you'll feel good, even after long hours of use -
1-year battery life
You can go for a year without battery hassles. An On/Off switch and smart sleep mode extend battery life, while an indicator light eliminates surprises. 2 -
Logitech reliability
You get the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty -
Logitech Advanced Optical Tracking
Enjoy precise clicking and pointing-on surfaces other optical mice can't handle-while navigating your favorite websites thanks to Logitech Advanced Optical Tracking -
Logitech Unifying receiver
The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse or keyboard-without the hassle of multiple USB receivers -
Comfort anywhere
The compact contoured design with soft rubber grips keeps you comfortable-even when you're on the go -
Good-bye, tricky touchpad
You'll enjoy smooth cursor control, precise tracking and easy text selection on the surfaces where you use your computer most -
Six-in-one power
The tiny Logitech Unifying receiver connects up to six Unifying-compatible devices with a powerful, reliable wireless connection (up to 25 meters) -
Year-long battery
You can go a full year without battery hassles. The On/Off switch helps conserve power, smart sleep mode extends battery life and an indicator light eliminates surprises
- Logitech M235 - mouse - 2.4 GHz - red
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Red
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Battery indicator, on/off power switch
- Battery
- 1 x AA type
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
- Compatible with Windows 7
- Mouse
- Wireless Receiver
- Red
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- 1 x USB - 4 pin USB Type A
- AA type
- Installed Qty
- 1
- OS Required
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.16 |
