Logitech M187 Wireless Mini Mouse Blue
Quicklinx: 8YVLWS00 Mfr#: 910-002733
Colours:
The Mini Mouse is so small it'll easily fit in your purse, handbag or pant pocket for extra-portability.
Say good-bye to cords and enjoy wireless freedom, so it's easy to use your mouse on the couch with your laptop - or even when you're hooking your laptop up to your TV.
  • EXTRA-SMALL SHAPE, GOES WHEREVER YOU GO
    You can take the Mini Mouse wherever you take your laptop-thanks to its pocket-ready, extra-small design
  • RELIABLE WIRELESS CONNECTION
    Say good-bye to cords and enjoy the freedom and convenience of wireless -fast data transmission and virtually no delays or dropouts.(up to 10 meters)
  • TINY NANO RECEIVER
    The nano receiver is so small it stays in your USB port-without worry of losing or breaking it. If you do need to remove it, it stores inside the mouse
  • LOGITECH RELIABILITY
    You get the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty
  • WORKS ON ALL OPERATING SYSTEMS
    Your mouse works with Windows , Mac, Chrome and Linux . No matter what type of computer you own today-or buy tomorrow-you can depend on your mouse to work like you expect
Logitech M187 - mouse - 2.4 GHz - blue
Mouse
Wireless - 2.4 GHz
Blue
5 cm x 8 cm x 2.5 cm
51 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Scrolling wheel, Nano wireless receiver
1 x AAA type
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Wireless Receiver
5 cm
8 cm
2.5 cm
51 g
Blue
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
1 x USB - 4 pin USB Type A
AAA type
Installed Qty
1
Limited warranty - 3 years
