The Mini Mouse is so small it'll easily fit in your purse, handbag or pant pocket for extra-portability.
Say good-bye to cords and enjoy wireless freedom, so it's easy to use your mouse on the couch with your laptop - or even when you're hooking your laptop up to your TV.
- Logitech M187 - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- 5 cm x 8 cm x 2.5 cm
- 51 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Scrolling wheel, Nano wireless receiver
- Battery
- 1 x AAA type
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
- Compatible with Windows 7
- 3 years warranty
- Mouse
- Wireless Receiver
- 5 cm
- 8 cm
- 2.5 cm
- 51 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Optical
- 1 x USB - 4 pin USB Type A
- AAA type
- Installed Qty
- 1
- OS Required
- Limited warranty - 3 years
