Logitech M170 Wireless Mouse
Quicklinx: DXWVWS00 Mfr#: 910-004642
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC
£11.24 ex VAT
£13.48 inc VAT
Logitech M170 has strong and consistent wireless connection from distances up to 10 m away. With virtually no delays or dropouts, you'll work and play with confidence. Just insert the receiver into a USB port on your computer and begin using it right away. There is no need to pair the mouse or to download software in order to begin using it. It is really comfortable and mobile. The shape of the mouse supports your hand for hours of comfortable use.
  • Reliable 2.4 Ghz wireless connection
    Strong, consistent wireless connection from distances up to 10 m (33 ft) away. With virtually no delays or dropouts, you'll work and play with confidence.
  • Extra long battery life
    Work for long time between battery changes. To extend the battery life, use the On/Off switch power off when not in use.
  • Plug-and-Play connection
    The M170 wireless mouse features a true Plug-and-Play. Just insert the receiver into a USB port on your computer and begin using it right away. There is no need to pair the mouse or to download software in order to begin using it.
  • Comfortable and mobile
    The shape of the mouse supports your hand for hours of comfortable use. The ambidextrous shape and the ability to reassign right and left button functions make M170 the ideal mouse for the right or left hand.
Logitech M170 - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
6.15 cm x 9.77 cm x 3.52 cm
70.5 g
Wireless Receiver
USB wireless receiver
Nano wireless receiver
AA type
Google Chrome OS
Mouse
Wireless Receiver
6.15 cm
9.77 cm
3.52 cm
70.5 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
1 x USB - 4 pin USB Type A
AA type
Run Time (Up To)
1 year
Google Chrome OS
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Logitech
