Logitech M110 Silent Mouse
Quicklinx: F44PWS00 Mfr#: 910-005489
Get all your work done without missing a beat or disturbing those around you. Silent mice have the same click feel without the click noise. A smooth scroll wheel completes the silent experience. Silent mice eliminate excess noise while protecting the health and productivity of everyone.
  • ENJOY THE SOUND OF SILENCE
    Get all your work done without missing a beat or disturbing those around you. Silent mice have the same click feel without the click noise–over 90% noise reduction. A smooth scroll wheel completes the silent experience. Silent mice eliminate excess noise while protecting the health and productivity of everyone. Make this your last annoying click. Your family and friends will thank you
  • WORK WITH LESS DISTRACTIONS
    Our innovative SilentTouch technology removes over 90% of disruptive sounds2Left click dBA level measured by independent lab at 1 meter from the center of the mouse. Compared with Logitech M170. for you and those around you-all while keeping the same clicking feel. Plus, it has feet made of high-performance material and a rubber wheel for quiet gliding and scrolling
  • SIMPLE TO SET UP AND USE
    Your mouse works right out of the box. No installation hassles. No software required. Setup is fast and easy-just plug the cable into a USB port and you're good to go
  • FULL-SIZE COMFORT, AMBIDEXTROUS DESIGN
    Left-handed or right, you'll be comfortable hour after hour with this full-size, ambidextrous design. The curved surface was designed to support your fingers just right in order to prevent fatigue
  • BUILT BY LOGITECH
    This mouse comes with the high quality and reliability that have made Logitech the global leader for mice and keyboards3Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only. -plus a three-year limited hardware warranty
  • BETTER THAN A TRACKPAD
    You're in control with smooth, responsive optical tracking that moves the cursor just where you want it. Edit documents and navigate the Web more efficiently than with a trackpad
  • DECADES OF DESIGN EXCELLENCE
    We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
Logitech M110 Silent - mouse - USB - red
Mouse
Wired - USB
Red
Orientation
Right and left-handed
6.17 cm x 11.296 cm x 3.84 cm
85 g
EMEA
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, Noiseless wheel technology
Cable Length
1.8 m
Microsoft Windows 7 / 8 / 10 or later, Apple MacOS X 10.5 or later, Google Chrome OS, Linux Kernel 2.6 or later
3-year warranty
Mouse
Orientation
6.17 cm
11.296 cm
3.84 cm
85 g
Red
EMEA
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Cable Length
1.8 m
1 x USB - 4 pin USB Type A
Quiet Mark, Plug and Play
Shipping Width
8.3 cm
Shipping Depth
18.6 cm
Shipping Height
12.6 cm
Shipping Weight
142 g
Limited warranty - 3 years
