Get all your work done without missing a beat or disturbing those around you. Silent mice have the same click feel without the click noise. A smooth scroll wheel completes the silent experience. Silent mice eliminate excess noise while protecting the health and productivity of everyone.
ENJOY THE SOUND OF SILENCE
Get all your work done without missing a beat or disturbing those around you. Silent mice have the same click feel without the click noise–over 90% noise reduction. A smooth scroll wheel completes the silent experience. Silent mice eliminate excess noise while protecting the health and productivity of everyone. Make this your last annoying click. Your family and friends will thank you -
WORK WITH LESS DISTRACTIONS
Our innovative SilentTouch technology removes over 90% of disruptive sounds2Left click dBA level measured by independent lab at 1 meter from the center of the mouse. Compared with Logitech M170. for you and those around you-all while keeping the same clicking feel. Plus, it has feet made of high-performance material and a rubber wheel for quiet gliding and scrolling -
SIMPLE TO SET UP AND USE
Your mouse works right out of the box. No installation hassles. No software required. Setup is fast and easy-just plug the cable into a USB port and you're good to go -
FULL-SIZE COMFORT, AMBIDEXTROUS DESIGN
Left-handed or right, you'll be comfortable hour after hour with this full-size, ambidextrous design. The curved surface was designed to support your fingers just right in order to prevent fatigue -
BUILT BY LOGITECH
This mouse comes with the high quality and reliability that have made Logitech the global leader for mice and keyboards3Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only. -plus a three-year limited hardware warranty -
BETTER THAN A TRACKPAD
You're in control with smooth, responsive optical tracking that moves the cursor just where you want it. Edit documents and navigate the Web more efficiently than with a trackpad -
DECADES OF DESIGN EXCELLENCE
We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
- Logitech M110 Silent - mouse - USB - red
- Mouse
- Connectivity Technology
- Wired - USB
- Red
- Orientation
- Right and left-handed
- 6.17 cm x 11.296 cm x 3.84 cm
- 85 g
- Localisation
- EMEA
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel, Noiseless wheel technology
- Cable Length
- 1.8 m
- OS Required
- Microsoft Windows 7 / 8 / 10 or later, Apple MacOS X 10.5 or later, Google Chrome OS, Linux Kernel 2.6 or later
- 3-year warranty
- Mouse
- Orientation
- 6.17 cm
- 11.296 cm
- 3.84 cm
- 85 g
- Red
- Localisation
- EMEA
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Cable Length
- 1.8 m
- 1 x USB - 4 pin USB Type A
- Quiet Mark, Plug and Play
- OS Required
- Shipping Width
- 8.3 cm
- Shipping Depth
- 18.6 cm
- Shipping Height
- 12.6 cm
- Shipping Weight
- 142 g
- Limited warranty - 3 years
