Just plug the mouse into a USB port and it's ready to use. No software or batteries required.
You'll enjoy smooth cursor control, precise tracking and easy text selection.
Your hand will be more comfortable than with your touchpad.
Simple to set up and use
Setup is fast and easy-just plug the cable into a USB port. There's no software to install. And since it's corded, you can just plug the cable into a USB port and use it right away -
High-definition optical tracking
You'll enjoy responsive, smooth cursor control and precise tracking and easy text selection thanks to high-definition optical tracking (1000 dpi) -
Full-size comfort, ambidextrous design
Designed to keep either hand happy. So you'll feel comfortable, even after hours of use -
Built by Logitech
This mouse comes with the quality and design we've built into more than a billion mice, more than any other manufacturer -
Plug and play
Just plug the mouse into a USB port and it's ready to use. No software or batteries required -
Logitech reliability
You get a mouse you can count on with the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty -
Smooth traveler
You'll enjoy smooth cursor control, precise tracking and easy text selection -
Comfy, contoured shape
- Logitech M105 - mouse - USB - red
- Mouse
- Connectivity Technology
- Wired - USB
- Red
- Movement Detection Technology
- Optical
- Scrolling wheel
- Cables Included
- 1 x USB cable - integrated
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Red
Input Device
- Wired
- Interface
- USB
- Optical
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- Cables Included
- Plug and Play
- OS Required
- Limited warranty - 3 years
