Logitech M100 White USB Optical Wired Mouse
Mouse M100
Quicklinx: 7HSSWS00 Mfr#: 910-001603
Logitech Mouse M100 gives you just the basics for comfortable, reliable control of your computer. There is no software to install. And since it is corded, you can just plug the cable into a USB port and use it right away. The full-size, ambidextrous shape means your hand will rest comfortably, while high-definition optical tracking (1000 dpi) means you will get responsive, smooth cursor control for precise tracking and easy text selection.
  • EASY PLUG-AND-PLAY
    It's nice and simple. Just plug the cable into the USB port and M100 is ready for use. No downloads, no setup, no fuss
  • COMFORT FOR EITHER HAND
    Left-handed or right, you'll be comfortable hour after hour with this full-size, ambidextrous design
  • DURABLE AND RELIABLE
    M100 is built with the same high quality and reliability standards that have made Logitech the global leader for mice and keyboards Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany,Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan,Turkey, UK, US (July '19 - July '20 period). Retail channel only.
  • BROAD COMPATIBILITY
    M100 works with Windows , macOS and Linux -plus, it's certified Works With Chromebook . This product has been certified to meet Google's compatibility standards. Google is not responsible for the operation of this product or its compliance with safety requirements. Chromebook and the "Works With Chromebook" badge are trademarks of Google LLC. So you can relax and rest assured that it'll work with your setup
  • SMOOTH NAVIGATION
    Accurate, line-by-line scrolling makes your everyday tasks smooth and easy
  • Decades of Design Excellence
    We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
Logitech M100 - mouse - USB - white
Mouse
Wired - USB
White
Orientation
Right and left-handed
6.1 cm x 11.2 cm x 3.9 cm
64 g
Western Europe
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel
Apple MacOS X 10.4 or later, Linux Kernel 2.6.x or later, Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
6.1 cm
11.2 cm
3.9 cm
64 g
White
Western Europe
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Additional Requirements
USB port
Limited warranty - 3 years
