Logitech Mouse M100 gives you just the basics for comfortable, reliable control of your computer. There is no software to install. And since it is corded, you can just plug the cable into a USB port and use it right away. The full-size, ambidextrous shape means your hand will rest comfortably, while high-definition optical tracking (1000 dpi) means you will get responsive, smooth cursor control for precise tracking and easy text selection.
Simple to set up and use
Setup is fast and easy-just plug the cable into a USB port. There's no software to install. And since it's corded, you can just plug the cable into a USB port and use it right away -
Full-size comfort, ambidextrous design
Designed to keep either hand happy. So you'll feel comfortable, even after hours of use -
High-definition optical tracking
You'll enjoy responsive, smooth cursor control and precise tracking and easy text selection thanks to high-definition optical tracking (1000 dpi) -
Built by Logitech
This mouse comes with the quality and design we've built into more than a billion mice, more than any other manufacturer
- Logitech M100 - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- Orientation
- Right and left-handed
- 6.1 cm x 11.2 cm x 3.9 cm
- 64 g
- Localisation
- Western Europe
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel
- OS Required
- Apple MacOS X 10.4 or later, Linux Kernel 2.6.x or later, Microsoft Windows Vista / XP / 7
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Orientation
- 6.1 cm
- 11.2 cm
- 3.9 cm
- 64 g
- Black
- Localisation
- Western Europe
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Scrolling wheel
- 1 x USB - 4 pin USB Type A
- OS Required
- Additional Requirements
- USB port
- Limited warranty - 3 years
