Logitech M100 - Mouse - Right and Left-Handed - Optical - 3 buttons - Wired - USB - Black
Quicklinx: HQVCWS00 Mfr#: 910-006652
Wired / Wireless: Wired
Colour: Black
47 In Stock
£8.74 ex VAT
£10.48 inc VAT
If the basics are all you need, you'll enjoy comfortable, reliable control of your computer.
  • EASY PLUG-AND-PLAY
    It's nice and simple. Just plug the cable into the USB port and M100 is ready for use. No downloads, no setup, no fuss
  • COMFORT FOR EITHER HAND
    Left-handed or right, you'll be comfortable hour after hour with this full-size, ambidextrous design
  • DURABLE AND RELIABLE
    M100 is built with the same high quality and reliability standards that have made Logitech the global leader for mice and keyboards2Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany,Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan,Turkey, UK, US (July '19 - July '20 period). Retail channel only.
  • BROAD COMPATIBILITY
    M100 works with Windows , macOS and Linux -plus, it's certified Works With Chromebook .3This product has been certified to meet Google's compatibility standards. Google is not responsible for the operation of this product or its compliance with safety requirements. Chromebook and the "Works With Chromebook" badge are trademarks of Google LLC. So you can relax and rest assured that it'll work with your setup
  • SMOOTH NAVIGATION
    Accurate, line-by-line scrolling makes your everyday tasks smooth and easy
  • Decades of Design Excellence
    We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
Logitech M100 - mouse - full size - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
6.2 cm x 11.3 cm x 3.8 cm
90 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel
Cable Length
1.8 m
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4 or later, Linux Kernel 2.6.x or later
3-year warranty
Mouse
Orientation
6.2 cm
11.3 cm
3.8 cm
90 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Cable Length
1.8 m
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play
Limited warranty - 3 years
Colour: Black
Brand: Logitech
