Logitech LS1 Laser Mouse - Wired USB
LS1 Laser Mouse
Quicklinx: 6B8GWS00 Mfr#: 910-001161
Whether you're surfing the web or checking your e-mail, you'll always look stylish when you're using the Logitech LS1 Laser Mouse. Sleek surfaces and colorful accent make your desktop setup look even better. Laser technology delivers smooth, accurate cursor control on virtually any surface. The soft rubber grip gives you comfort and control during long sessions. Just connect the mouse to a USB port to get started. Install the software to enjoy side-to-side scrolling plus zoom, perfect for viewing photos and navigating spreadsheets: instantly zoom in and out, and easily scroll horizontally and vertically.
  • Enhanced compatibility
    Designed to seamlessly integrate with both Mac and PC systems, this mouse offers versatile use across different devices, ensuring a smooth user experience no matter the platform.
  • Precision tracking
    Equipped with laser movement detection technology, this mouse provides accurate and smooth cursor control, enhancing productivity and efficiency in every task.
  • Comfortable design
    Featuring a soft rubber grip and a scrolling wheel, the design of this mouse prioritizes user comfort, making it suitable for extended use without strain.
Logitech LS1 - mouse - USB - berry
Mouse
Wired - USB
Berry
Western Europe
Movement Detection Technology
Laser
Scrolling wheel, soft rubber grip
1 x USB cable - integrated
Apple MacOS X 10.3.9 or later, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Berry
Western Europe
Input Device
Wired
USB
Laser
1 x USB - 4 pin USB Type A
Limited warranty - 3 years
Resources
The following resources are available for the Logitech LS1 Laser Mouse - Wired USB
