Elevate audio quality to an "I can't tell you're on a speakerphone" experience - with freedom from holding a phone to your ear. Advanced DSP technology enables precise tuning for both the microphone and speaker so conversations are more life-like. An integrated stand positions a mobile phone or tablet at just the right angle for shake-free video calls and hands-free access to the mobile screen. Hear and be heard in true wideband audio, so those on both sides of the call can enjoy a life-like communication experience. Plug a headphone directly into the Mobile Speakerphone P710e when additional privacy is desired.
FLEXIBLE HANDS-FREE CONFERENCING
For the multitasking professional, the Logitech P710e speakerphone lets you instantly connect and start a video conference using your mobile device. The P710e holds your device steady for undisturbed visibility on the other end of the call while you take notes or type on a second device or computer -
TAKE THE MOBILE P710E ANYWHERE
When you need to take a call in a busy office, at home, or in a hotel room, the P710e speakerphone provides long battery life with up to 15 hours of talk time. A custom speaker and noise-cancelling mic offer clear sound on both ends of the call. Plug headphones into the P710e for additional privacy -
CONNECT INSTANTLY TO A MEETING
When you're ready to jump on a call, connect your mobile phone or tablet to the P710e speakerphone using Bluetooth with optional NFC pairing or the attached USB cable. Pair up to eight Bluetooth devices. Easily pair and unpair NFC-enabled mobile devices to the P710e by simply touching them together -
DESIGNED FOR BUSINESS
Video conferencing is easy with the P710e. Optimized for Microsoft Lync , Cisco compatible1, and certified for Skype and Skype for Business, the P710e provides enterprise-quality audio and an integrated conferencing experience -
INTEGRATED STAND
An integrated stand positions a mobile phone or tablet at just the right angle for shake-free video calls and hands-free access to the mobile screen -
NOISE & ECHO CANCELLATION
With acoustic echo cancellation and a noise-cancelling microphone, P710e is optimized so you can hear and be heard, even in noisy workspaces -
LONG BATTERY LIFE
Up to 15 hours of talk time between charges the Mobile Speakerphone P710e outlasts the longest workday -
OPTIMIZED FOR VOICE AND MUSIC
A dynamic equalizer automatically switches between voice and music modes, delivering the best sound quality for what the user is listening to -
TOUCH CONTROLS
Touch controls with LED indicators provide excellent response without transmitting audible noise through the audio path -
INTEGRATED USB CABLE
The USB cable is hardwired into the speakerphone so it's never lost and neatly coils away beneath the unit when not in use
- Logitech Mobile Speakerphone P710e - speakerphone
- Product Type
- Speakerphone - Bluetooth - wireless, wired - NFC
- Recommended Use
- Portable electronics, computer - communication
- Additional Functions
- LED lights
- Connectivity Technology
- Wireless, wired
- Wireless Technology
- Bluetooth
- Audio Specifications
- Frequency Response 140 - 16000 Hz
- Microphone
- Built-in
- Microphone Operation Mode
- Omni-directional
- Controls
- Volume, answer/end
- 2-year warranty
- Product Type
- LED lights
- 12 cm
- 12 cm
- 4 cm
- 275 g
- Recommended Use
Audio Output
- Wireless, wired
- Bluetooth
- 140 - 16000 Hz
- Dynamic Range
- 85 dB
Microphone
- Omni-directional
- Directivity Angle
- 360°
- 50 - 8000 Hz
Remote Control
- Controls
- Connector Type
- USB (4 PIN USB Type A) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Carrying case, spacer
- Cable Details
- USB cable
- Power Device
- Power adapter - external
- Battery
- Speaker phone battery rechargeable
- Run Time (Up To)
- 15 hour(s)
- Limited warranty - 2 years
