Logitech Logitech MeetUp Conference Cam
Quicklinx: CY1MWS00 Mfr#: 960-001102
More than 50 In Stock
£566.06 ex VAT
£679.27 inc VAT
Standard delivery Delivered within 3-5 working days
MeetUp is designed for small conference rooms and huddle rooms. Stop crowding around laptops. With advanced optics and a wide 120º field of view, MeetUp makes every seat at the table clearly visible. And its integrated audio is optimized for huddle room acoustics, ensuring everyone can be heard as well as seen.
  • A WIDE VIEW FOR TIGHT SPACES
    Logitech MeetUp brings remarkable video quality to small conference rooms. Its 120-degree field-of-view easily accommodates huddle rooms where people sit on either side of the camera. The 4K ultra high-def sensor and Logitech lens deliver extra sharp clarity, while pan, tilt, and zoom controls let you focus on presenters and their visual aids
  • HEARING IS BELIEVING
    MeetUp's integrated audio is optimized for huddle room acoustics, delivering exceptional sound in small rooms. Three beamforming mics and a custom-tuned speaker ensure meetings sound as great as they look. Add Expansion Mic for MeetUp to extend the audio range up to 4.2 meters
  • AS EASY AS PLUG AND PLAY
    Step into a huddle room and instantly start a video collaboration. MeetUp plugs into a USB port and simply works. Use any video conferencing software application and cloud service, including the ones you already use
  • DESIGNED FOR THE WAY PEOPLE MEET
    Small conference rooms are growing in popularity, and MeetUp rises to the challenge. It provides superb resolution, color balance, detail, and audio in tight spaces. With the included wall mount and compact design that minimizes cable clutter, MeetUp optimizes the huddle room experience
  • EXTRAS PROVIDE MORE CONVENIENCE
    Our free mobile app (available on Google Play and iTunes ) turns your smartphone or tablet into a remote control for MeetUp. Add accessories such as the Logitech Expansion Mic and TV Mount for different room sizes and configurations. Order replacement parts if needed to keep everything up and running
  • 5x Zoom
    Perfectly frame presenters to minimize background distractions. Zoom in on whiteboards and objects so remote participants can see what you see. Thanks to its advanced 4K image sensor, video remains sharp and clear, even when you zoom in on the details
  • Premium Camera Optics
    MeetUp features exquisitely engineered, premium camera optics that capture a wide field-of-view without distorting faces and furniture with a 'fisheye' effect. Faces look natural, whiteboard writing remains legible, and straight lines stay straight
  • Expansion Mic-Ready
    Logitech Expansion Mic for MeetUp provides greater flexibility in huddle room configurations. MeetUp's built-in beamforming mics are optimized for up to 8 feet (2.4 meters). To extend that range up to 14 feet (4.2 meters), add an Expansion Mic. So whether people are seated at a table, sitting against the wall, or walking around the room, Expansion Mic for MeetUp means everyone will be heard
  • Certified for Business
    MeetUp offers a plug-and-play USB connection to conference room computers, and is certified for Skype for Business, Microsoft Cortana , Cisco Jabber compatible, and offers enhanced integration with BlueJeans, Broadsoft, LifeSize Cloud, Vidyo, and Zoom. If your preferred application can recognize a webcam, you can use it with MeetUp
  • Bluetooth Speakerphone
    Already connected on your smartphone? Dialing into an audio conference? Pair MeetUp with your smartphone or tablet to enjoy outstanding audio clarity, volume, and range that handheld devices can't match
  • RF Remote Control
    With a multi-directional remote control, you can easily operate camera controls, adjust volume, and mute/unmute from anywhere in the room. Featuring a low-profile design, premium materials, and a non-slip base, the MeetUp Remote Control feels as good on the tabletop as it does in your hand
  • Versatile TV Mount
    Logitech TV Mount for MeetUp lets you mount the MeetUp ConferenceCam either above or below a flat-panel monitor, and attaches to the industry-standard VESA mounting points available on most TVs and monitors
  • Smartphone Remote Control
    The ConferenceCam Soft Remote app (available on Google Play and iTunes) replicates every function of the physical MeetUp remote on your smartphone or tablet
Logitech MeetUp - conference camera
Conference camera - pan / tilt
Audio
Yes: built-in speaker, built-in three microphones
Camera Mount Type
Wall mount
40 cm x 10.4 cm x 8.5 cm
1.04 kg
Wired, wireless
Camera
Max Resolution
3840 x 2160
Frame Rate (max)
30 frames per second
Video Modes
720p, 1080p, 4K
Focus Adjustment
Automatic
Panning Range (degree)
-25 to +25
Tilting Range (degree)
-15 to +15
USB 3.0 Bluetooth LE / NFC
Intelligent Assistant
Cortana
1 - USB-C cable - 5 m
RightLight technology, security lock slot (cable lock sold separately), Jabber compatible, WebEx compatible, Skype for Business compatible
Conference camera
Audio Support
Camera Mount Type
Wall mount
Wired, wireless
40 cm
10.4 cm
8.5 cm
1.04 kg
Camera
Colour - pan / tilt
Digital Video Format
MJPEG
Max Digital Video Resolution
3840 x 2160
Video Modes
720p, 1080p, 4K
Digital Zoom
5
Video Capture
3840 x 2160 @ 30 fps , 1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps
Lens Construction
Focus Adjustment
Automatic
Vertical Field of View (degree)
120
Panning
Range (degree)
-25 to +25
Tilting
Range (degree)
-15 to +15
Network Interface
Bluetooth LE / NFC
Computer Interface
USB 3.0
Ports
USB 3.0 - 24-pin USB-C
Remote control, wall mount kit
1 x USB-C cable - 5 m
Plug and Play
Power adapter - external
Lithium Ion
Apple MacOS X 10.10 or later, Microsoft Windows 7 / 8.1 / 10
System Requirements Details
Windows 7 - Intel Core Duo - 2.4 GHz - RAM 2 GB
Internet of Things (IoT)
Communications Technology
Bluetooth Low Energy (LE)
Cortana
CY1M Logitech TV Mount for MeetUP In Stock £69.89
CY1M Logitech Expansion Mic for MeetUp In Stock £145.29
CY1M Logitech Meetup Mic Extension Cable - Graphite In Stock £91.88
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: CY1M 051192
Condition: Opened, used and in good condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £349.32
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Video Conference Kit
Brand: Logitech
Price Range Ex VAT: £500 - £750
Stock Status: Used Stock
