MeetUp is designed for small conference rooms and huddle rooms. Stop crowding around laptops. With advanced optics and a wide 120º field of view, MeetUp makes every seat at the table clearly visible. And its integrated audio is optimized for huddle room acoustics, ensuring everyone can be heard as well as seen.
A WIDE VIEW FOR TIGHT SPACES
Logitech MeetUp brings remarkable video quality to small conference rooms. Its 120-degree field-of-view easily accommodates huddle rooms where people sit on either side of the camera. The 4K ultra high-def sensor and Logitech lens deliver extra sharp clarity, while pan, tilt, and zoom controls let you focus on presenters and their visual aids -
HEARING IS BELIEVING
MeetUp's integrated audio is optimized for huddle room acoustics, delivering exceptional sound in small rooms. Three beamforming mics and a custom-tuned speaker ensure meetings sound as great as they look. Add Expansion Mic for MeetUp to extend the audio range up to 4.2 meters -
AS EASY AS PLUG AND PLAY
Step into a huddle room and instantly start a video collaboration. MeetUp plugs into a USB port and simply works. Use any video conferencing software application and cloud service, including the ones you already use -
DESIGNED FOR THE WAY PEOPLE MEET
Small conference rooms are growing in popularity, and MeetUp rises to the challenge. It provides superb resolution, color balance, detail, and audio in tight spaces. With the included wall mount and compact design that minimizes cable clutter, MeetUp optimizes the huddle room experience -
EXTRAS PROVIDE MORE CONVENIENCE
Our free mobile app (available on Google Play and iTunes ) turns your smartphone or tablet into a remote control for MeetUp. Add accessories such as the Logitech Expansion Mic and TV Mount for different room sizes and configurations. Order replacement parts if needed to keep everything up and running -
5x Zoom
Perfectly frame presenters to minimize background distractions. Zoom in on whiteboards and objects so remote participants can see what you see. Thanks to its advanced 4K image sensor, video remains sharp and clear, even when you zoom in on the details -
Premium Camera Optics
MeetUp features exquisitely engineered, premium camera optics that capture a wide field-of-view without distorting faces and furniture with a 'fisheye' effect. Faces look natural, whiteboard writing remains legible, and straight lines stay straight -
Expansion Mic-Ready
Logitech Expansion Mic for MeetUp provides greater flexibility in huddle room configurations. MeetUp's built-in beamforming mics are optimized for up to 8 feet (2.4 meters). To extend that range up to 14 feet (4.2 meters), add an Expansion Mic. So whether people are seated at a table, sitting against the wall, or walking around the room, Expansion Mic for MeetUp means everyone will be heard -
Certified for Business
MeetUp offers a plug-and-play USB connection to conference room computers, and is certified for Skype for Business, Microsoft Cortana , Cisco Jabber compatible, and offers enhanced integration with BlueJeans, Broadsoft, LifeSize Cloud, Vidyo, and Zoom. If your preferred application can recognize a webcam, you can use it with MeetUp -
Bluetooth Speakerphone
Already connected on your smartphone? Dialing into an audio conference? Pair MeetUp with your smartphone or tablet to enjoy outstanding audio clarity, volume, and range that handheld devices can't match -
RF Remote Control
With a multi-directional remote control, you can easily operate camera controls, adjust volume, and mute/unmute from anywhere in the room. Featuring a low-profile design, premium materials, and a non-slip base, the MeetUp Remote Control feels as good on the tabletop as it does in your hand -
Versatile TV Mount
Logitech TV Mount for MeetUp lets you mount the MeetUp ConferenceCam either above or below a flat-panel monitor, and attaches to the industry-standard VESA mounting points available on most TVs and monitors -
Smartphone Remote Control
The ConferenceCam Soft Remote app (available on Google Play and iTunes) replicates every function of the physical MeetUp remote on your smartphone or tablet
- Logitech MeetUp - conference camera
- Conference camera - pan / tilt
- Audio
- Yes: built-in speaker, built-in three microphones
- Camera Mount Type
- Wall mount
- 40 cm x 10.4 cm x 8.5 cm
- 1.04 kg
- Connectivity Technology
- Wired, wireless
- Camera
- Max Resolution
- 3840 x 2160
- Frame Rate (max)
- 30 frames per second
- Video Modes
- 720p, 1080p, 4K
- Focus Adjustment
- Automatic
- Panning Range (degree)
- -25 to +25
- Tilting Range (degree)
- -15 to +15
- USB 3.0 Bluetooth LE / NFC
- Intelligent Assistant
- Cortana
- Cables Included
- 1 - USB-C cable - 5 m
- RightLight technology, security lock slot (cable lock sold separately), Jabber compatible, WebEx compatible, Skype for Business compatible
- 2-year warranty
- Conference camera
- Audio Support
- Camera Mount Type
- Wall mount
- Wired, wireless
- 40 cm
- 10.4 cm
- 8.5 cm
- 1.04 kg
Camera
- Colour - pan / tilt
- Digital Video Format
- MJPEG
- Max Digital Video Resolution
- 3840 x 2160
- Video Modes
- 720p, 1080p, 4K
- Digital Zoom
- 5
- Video Capture
- 3840 x 2160 @ 30 fps , 1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps
Lens Construction
- Focus Adjustment
- Automatic
- Vertical Field of View (degree)
- 120
Panning
- Range (degree)
- -25 to +25
Tilting
- Range (degree)
- -15 to +15
- Network Interface
- Bluetooth LE / NFC
- Computer Interface
- USB 3.0
- Ports
- USB 3.0 - 24-pin USB-C
- Included Accessories
- Remote control, wall mount kit
- Cables Included
- 1 x USB-C cable - 5 m
- Plug and Play
- Power Device
- Power adapter - external
- Battery
- Lithium Ion
- OS Required
- Apple MacOS X 10.10 or later, Microsoft Windows 7 / 8.1 / 10
- System Requirements Details
- Windows 7 - Intel Core Duo - 2.4 GHz - RAM 2 GB
Internet of Things (IoT)
- Communications Technology
- Bluetooth Low Energy (LE)
- Cortana
- Limited warranty - 2 years
Logitech TV Mount for MeetUP | In Stock | £74.04 |
Logitech Expansion Mic for MeetUp | In Stock | £189.72 |
Logitech Meetup Mic Extension Cable - Graphite | In Stock | £98.45 |
Logitech Meetup Remote Control | In Stock | £44.74 |
