You heard it from us first! That's because an intuitive mouse shaped like Lift can help long hours at work feel less 'ouch!' and more 'ahhhhh'. Intrigued? Find out what Funso, Elin and Lucy have to say about it.
Vertical is the new pink
You heard it from us first! That's because an intuitive mouse shaped like Lift can help long hours at work feel less 'ouch!' and more 'ahhhhh' -
Raise your hand into comfort
Rest your hand on a softly textured grip, with easy-to-reach buttons that help you work all day without lifting a finger. It even has a cosy thumb rest -
Realign into ouch-less work hours
Lift's optimal 57° angle places you in what we like to call "natural handshake position". This puts less pressure on your wrist throughout the day and places your arm and upper body in a more natural posture -
Relax into focus, all day long
With a more relaxed upper body, your mind can focus on the things that really matter. Stay zen from a.m. to p.m. with whisper-quiet clicks and a smooth-gliding, quiet scroll wheel that adapts to the lightest touch -
A great fit for small to medium hands
Lift's organic silhouette fits small to medium hands like a glove - specially designed and sculpted by Logitech's team of ergonomic and design experts -
Approved by experts
Designed, developed and tested in The Logi Ergo Lab, and with the stamp of approval from leading ergonomic institutions, you can rest assured Lift means business when it comes to your wellbeing in the workspace -
Fast to connect and long-lasting
Connect easy using Bluetooth Low Energy or the included Logi Bolt USB receiver - ideal for congested environments like the office. Enjoy up to 2 years of productivity, powered by a single AA battery included in the box -
Feel the Wave. Feel the Lift
Pair Lift with Wave keys, and turn your desk life into a feel-good story with an ergonomic keyboard and mouse matched for day-long comfort
- Logitech Lift Vertical Ergonomic Mouse - vertical mouse - Bluetooth, 2.4 GHz - graphite
- Vertical mouse - ergonomic
- Connectivity Technology
- Wireless - Bluetooth, 2.4 GHz
- Graphite
- Orientation
- Left-handed
- 7 cm x 10.8 cm x 7.1 cm
- 125 g
- Wireless Receiver
- Logitech Logi Bolt USB receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 6
- Movement Resolution
- 4000 dpi
- Performance
- Realtime sensitivity switching 400 - 4000 dpi
- Soft rubber grip, SmartWheel, thumb rest, 57° tilt angle, 4 programmable buttons, Logitech Flow
- Battery
- AA type
- OS Required
- Windows 10 / 11 or later, Apple macOS 10.15 or later, Apple iPadOS 14 or later, Android 8.0 (Oreo) or later, Google Chrome OS, Linux
- Product Recycled Content
- 70 % - made of recycled plastic
- Works With Chromebook
- 2-year warranty
- Vertical mouse
- Wireless Receiver
- Ergonomic Design
- Orientation
- Left-handed
- 7 cm
- 10.8 cm
- 7.1 cm
- 125 g
- Product Material
- Plastic
- Graphite
Input Device
- Wireless
- Interface
- Max Operating Distance
- Up to 10 m
- Optical
- Buttons Qty
- 6
- 4000 dpi
- Performance
- 1 x USB - 4 pin USB Type A
- Included Accessories
- 1 AA battery
Sustainability Information
- AA type
- Run Time (Up To)
- 2 years
- OS Required
- Limited warranty - 2 years
