The optimal 57° angle of Lift for Mac places your hand in what we like to call "natural handshake position". This puts less pressure on your wrist throughout the day and places your arm and upper body in a more natural posture.
Realign into comfort
The optimal 57° angle of Lift for Mac places your hand in what we like to call "natural handshake position". This puts less pressure on your wrist throughout the day and places your arm and upper body in a more natural posture -
Rest your hand onto bliss
Rest your hand on a softly textured grip, with easy-to-reach buttons that help you work all day without lifting a finger. It even has a cozy thumb rest -
Relax into focus, all day long
With a more relaxed upper body, your mind can focus on the things that really matter. Stay zen from a.m. to p.m. with whisper-quiet clicks and a smooth-gliding, quiet scroll wheel that adapts to the lightest touch -
A great fit for small to medium hands
The organic silhouette of Lift for Mac fits small to medium hands like a glove - specially designed and sculpted by Logitech's team of ergonomic and design experts. Not sure what size your hand is? -
Fast to connect and long-lasting
Connect easy to up to 3 macOS or iPadOS devices using Bluetooth Low Energy and enjoy up to 2 years of productivity5Battery life may vary based on user and computing conditions., powered by a single AA battery included in the box
- Logitech Lift for Mac - vertical mouse - Bluetooth - off-white
- Vertical mouse - ergonomic
- Connectivity Technology
- Wireless - Bluetooth
- Off-white
- 7 cm x 10.8 cm x 7.1 cm
- 125 g
- Localisation
- EMEA
- Wireless Receiver
- Logitech Logi Bolt USB receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 6
- Movement Resolution
- 4000 dpi
- Performance
- Realtime sensitivity switching 400 - 4000 dpi
- Soft rubber grip, SmartWheel, thumb rest, 57° tilt angle, 4 programmable buttons
- Battery
- AA type
- OS Required
- Apple macOS 11 or later, Apple iPadOS 14 or later
- Product Recycled Content
- 54 % - made of recycled post-consumer plastic
- Designed For
- Apple MacBook
- Vertical mouse
- Wireless Receiver
- Ergonomic Design
- 7 cm
- 10.8 cm
- 7.1 cm
- 125 g
- Product Material
- Plastic
- Off-white
- Localisation
- EMEA
Input Device
- Wireless
- Interface
- Bluetooth
- Max Operating Distance
- Up to 10 m
- Optical
- Buttons Qty
- 6
- 4000 dpi
- Performance
- Included Accessories
- 1 AA battery
Sustainability Information
- AA type
- Run Time (Up To)
- 2 years
- OS Required
- Designed For
- Apple MacBook
Logitech Lift-Mac Ergo Mouse - White/Grey
