Logitech Lift-Mac Ergo Mouse - White/Grey
Quicklinx: HFSGWS00 Mfr#: 910-006477
Recommended Use: Office, Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Off-white
Compatibility: PC
Hurry, only 2 left in stock!
£57.68 ex VAT
£69.21 inc VAT
The optimal 57° angle of Lift for Mac places your hand in what we like to call "natural handshake position". This puts less pressure on your wrist throughout the day and places your arm and upper body in a more natural posture.
  • Realign into comfort
  • Rest your hand onto bliss
    Rest your hand on a softly textured grip, with easy-to-reach buttons that help you work all day without lifting a finger. It even has a cozy thumb rest
  • Relax into focus, all day long
    With a more relaxed upper body, your mind can focus on the things that really matter. Stay zen from a.m. to p.m. with whisper-quiet clicks and a smooth-gliding, quiet scroll wheel that adapts to the lightest touch
  • A great fit for small to medium hands
    The organic silhouette of Lift for Mac fits small to medium hands like a glove - specially designed and sculpted by Logitech's team of ergonomic and design experts. Not sure what size your hand is?
  • Fast to connect and long-lasting
    Connect easy to up to 3 macOS or iPadOS devices using Bluetooth Low Energy and enjoy up to 2 years of productivity5Battery life may vary based on user and computing conditions., powered by a single AA battery included in the box
Logitech Lift for Mac - vertical mouse - Bluetooth - off-white
Vertical mouse - ergonomic
Wireless - Bluetooth
Off-white
7 cm x 10.8 cm x 7.1 cm
125 g
EMEA
Wireless Receiver
Logitech Logi Bolt USB receiver
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
4000 dpi
Performance
Realtime sensitivity switching 400 - 4000 dpi
Soft rubber grip, SmartWheel, thumb rest, 57° tilt angle, 4 programmable buttons
AA type
Apple macOS 11 or later, Apple iPadOS 14 or later
Product Recycled Content
54 % - made of recycled post-consumer plastic
Apple MacBook
Vertical mouse
Wireless Receiver
Ergonomic Design
7 cm
10.8 cm
7.1 cm
125 g
Product Material
Plastic
Off-white
EMEA
Input Device
Wireless
Bluetooth
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
6
Movement Resolution
4000 dpi
Performance
1 AA battery
Sustainability Information
AA type
Run Time (Up To)
2 years
Apple MacBook
Recommended Use: Leisure
Type: Mouse
Colour: Off-white
Compatibility: PC
Brand: Logitech
