Logitech Keys-To-Go Keyboard - Wireless Connection
Quicklinx: FXCSWS00 Mfr#: 920-007645
Keys-To-Go is the super-slender, uber-handy, ultra-portable, fit-anywhere, go-everywhere keyboard.
  • You're going places - take a keyboard
    Keys-To-Go packs light, types comfortably and never leaves you at a loss for words.
  • Exactly what you expect from a keyboard
    Well-spaced keys with feedback for comfort. Keyboard shortcuts for productivity. Bluetooth wireless pairing. Rechargeable battery.
  • Life gets messy - wipe it clean
    The durable FabricSkin wards off dirt, crumbs and spills no matter, where you are or what you do.
  • Wherever you go, say it in style
    With the portable keyboard you can take anywhere. Keys-To-Go.
Logicool Keys-To-Go - keyboard - black
Keyboard
Bluetooth
24.2 cm x 13.7 cm x 0.6 cm
180 g
Keyboard
Bluetooth
Input Device
24.2 cm
13.7 cm
0.6 cm
180 g
USB power cable, stand
Microsoft Windows 7 or later, Android 4.1 (Jelly Bean) or higher
