Keys-To-Go, the super slender, handy, ultra portable, fit anywhere, go everywhere keyboard. Keys-To-Go packs light, types comfortably and never leaves you at a loss for words. Well-spaced keys with feedback for comfort. iOS keyboard shortcuts for productivity. Bluetooth wireless pairing. The durable FabricSkin wards off dirt, crumbs and spills no matter where you are or what you do.
Exactly what you expect from a Logitech keyboard
Well-spaced keys with feedback for comfort. iOS keyboard shortcuts for productivity. Bluetooth wireless pairing. -
Life gets messy - wipe it clean
The durable FabricSkin wards off dirt, crumbs and spills no matter where you are or what you do. -
Wherever you go, say it in style
With the portable keyboard you can take anywhere.
- Logitech Keys-To-Go Ultra-portable - keyboard - UK - black
- Keyboard
- Interface
- Bluetooth
- Localization and Layout
- UK
- Hot Keys Function
- Application switching, search, mute, play/pause, previous track, next track, home screen, screenshot, on screen keyboard, battery check button, volume -, volume +
- Black
- 24.2 cm x 13.7 cm x 0.6 cm
- 182 g
- 1-year warranty
- Keyboard
- Interface
- Bluetooth
- Max Operating Distance
- Up to 10 m
Input Device
- Hot Keys Function
- UK
- 24.2 cm
- 13.7 cm
- 0.6 cm
- 182 g
- Black
- Included Accessories
- USB power cable
- Rechargeable
- Installed Qty
- 1
- Limited warranty - 1 year
