Logitech Keyboard K120 - USB
Keyboard K120
Quicklinx: 7FGWWS00 Mfr#: 920-002524
Recommended Use: Leisure, Office
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
Hurry, only 3 left in stock!
£9.34 ex VAT
£11.20 inc VAT
Your hands will enjoy the low-profile, whisper-quiet keys and standard layout with full-size F-keys and number pad. The slim keyboard isn't just sleek-it's tough with a spill-resistant design, sturdy tilt legs and durable keys. You simply plug it into a USB port on your desktop, laptop or netbook computer and start using it right away.
With low-profile keys, a standard layout and a sleek yet sturdy design, this USB keyboard gives you a better typing experience that's built to last.
Comfortable, quiet typing
You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound and standard layout with full-size F-keys and number pad.
Spill-resistant design
Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills
Thin profile
The keyboard has a thin profile that adds a sleek look to your desk while keeping your hands in a more comfortable, neutral position.
Durable keys
The keys can last up to 10 million keystrokes so you can keep typing long after many keyboards have called it quits
Plug-and-play USB connection
Setup is simple--you just plug it into a USB port on your desktop, laptop or netbook computer and start using it right out of the box.
Easy-to-read keys
The bold, bright white characters make the keys easier to read--perfect for those with less-than-perfect vision. They're less likely to wear off, too.
Curved space bar
It keeps your hands in a more natural position so you can type in greater comfort.
Logitech reliability
You get the high quality and reliability that's made Logitech the global leader for keyboards and mice at a price you can afford--plus a 3-year warranty.
  • Comfortable, quiet typing
    You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound to minimize distractions
  • Industry standard key layout
    You get a layout you're used to with full-size F-keys to make things easier if you use keyboard templates
  • Spill-resistant design
    Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills. 1
  • Thin profile
  • Durable keys
  • Sturdy, adjustable tilt legs
    You can extend the sturdy folding legs to increase the keyboard tilt by 8 degrees to address your personal ergonomic needs
  • Plug-and-play USB connection
    Simple setup saves you time and resources-you just plug it into a USB port and start using it right away without software
  • Easy-to-read keys
    The bold, bright white characters make the keys easier to read-perfect for those with less-than-perfect vision. They're less likely to wear off, too
  • Curved space bar
  • Logitech reliability
    You get the high quality and reliability that's made Logitech the global leader for keyboards and mice at a price you can afford-plus a 3-year limited hardware warranty
  • Type smarter
    Your hands will enjoy the low-profile, virtually silent keys and standard layout with full-size F-keys and number pad
  • A tough worker
  • Easy does it
    You'll be ready for business in no time with this plug-and-play keyboard-no software needed
Logitech K120 - keyboard - UK Input Device
Keyboard
USB
Wired
Localization and Layout
Spillproof
45 cm x 15.5 cm x 2.4 cm
0.55 kg
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
USB
Region
United Kingdom
Spillproof
45 cm
15.5 cm
2.4 cm
0.55 kg
1 x USB cable - 1.5 m
Plug and Play, UL, TUV, VCCI, BSMI, cUL, FCC, KCC, WEEE
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7
Limited warranty - 3 years
Recommended Use: Office
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
