Logitech Keyboard Case for iPad 2 & iPad 3
Quicklinx: 7V7GWS00 Mfr#: 920-003411
Made for iPad 2 & iPad 3
Smart and sleek, ZAGG's patent-pending, award-winning protective case design provides an extra measure of convenience and style. You and your iPad 2 & iPad 3 won't want to go anywhere without it.
Take a stand
Go from FaceTime to email time in no time. A recess just behind the keyboard holds iPad 2 in either portrait or landscape modes. The choice is yours.
Just your type
The Logitech-designed wireless keyboard pairs quickly and easily over Bluetooth®. And the keyboard charges over USB, so you never need to worry about replacing batteries.
Better together
The ideal match for iPad 2 or iPad 3, the Keyboard Case is carefully crafted from precision-cut, aircraft-grade aluminum, so it fits, feels and looks great.
Soft on the inside
The inside corners are lined with high-density padding to help cushion and protect iPad 2 or iPad 3 if accidentally dropped.
Smooth operator
When typing on your iPad with your Logitech keyboard, you can gain time by using shortcuts for the commands you use most often, such as copy, paste, undo and many more.
  • Made for iPad 2
    Smart and sleek, ZAGG's patent-pending protective case design provides an extra measure of convenience and style. You and your iPad 2 won't want to go anywhere without it.
  • Take a stand
  • Just your type
    The Logitech-designed wireless keyboard pairs quickly and easily over Bluetooth. And the keyboard charges over USB, so you never need to worry about replacing batteries.
  • Better together
    The ideal match for iPad 2, the keyboard case is carefully crafted from precision-cut, aircraft-grade aluminum, so it fits, feels and looks great.
  • Soft on the inside
    The inside corners are lined with high-density padding to help cushion and protect iPad 2 if accidentally dropped.
Keyboard
Wired / Wireless
Wireless
Compatibility
iPad 2 and iPad 3
Black/silver
Pack Size
1
