Logitech K780 Multi-Device Keyboard Bluetooth, 2.4 GHz UK English
Quicklinx: CHRQWS00 Mfr#: 920-008041
Recommended Use: Mobile, Office, Leisure
Type: Keyboard
Wired / Wireless: Wireless
Colour: White
Compatibility: Apple iOS, Mac, PC, Android
18 In Stock
£69.69 ex VAT
£83.62 inc VAT
  • ONE KEYBOARD, EVERY DEVICE
    Meet K780, a compact keyboard that's designed for today's multi-tasking era. Compatible with up to three devices, you can switch typing between your phone, tablet, and computer in one easy flow. Durable and compact, it's also a space-saver that can withstand hours and hours of comfortable use
  • MULTI-DEVICE FLOW
    Connect up to three devices and switch between them. Easy-Switch lets you type on your laptop or computer, and then keep typing on your phone or tablet-all with the touch of a button. Unlock more customizations with Logi Options+ Software that lets you customize keys, create hotkey shortcuts or check the battery level
  • COMPACT WITH AN INTEGRATED CRADLE
    All the keys you need in a compact form factor that is ideal for smaller frames or tight workspaces. With a built-in numpad you can perform all your data entry with less reaching, and more room for your mouse. The integrated rubber cradle holds a variety of devices at a comfortable viewing angle, from smart phones to a 12" iPad
  • COMFY, QUIET & PRECISE TYPING
    Perfect Stroke keys are carefully crafted to provide a fluid and ultra-precise typing experience – with a responsiveness you feel, but don't hear. The round key design matches the shape of your fingertips, for a soft and comfortable typing feeling
  • FLEXIBLE AND COMPATIBLE
    Connect the way you want. K780 can be swiftly paired via Bluetooth wireless technology or the Unifying USB receiver. Compatible with Windows , ChromeOS , macOS , Android , iOS and iPadOS - it even maps keys and shortcuts to your preferred operating system, so you can easily flow from one device to another
  • BUILT TO KEEP GOING
    K780 is built with the same high quality and reliability standards that have made Logitech the global leader for mice and keyboards. Up to 24 months of battery life eliminates the hassle of frequent battery changes, with a handy on/off switch and power-saving technology that preserve battery life
Logitech K780 Multi-Device - keyboard - UK - white Input Device
Keyboard
Bluetooth, 2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
Hot Keys Function
Application switching, search, Easy-Switch
White
38 cm x 15.8 cm x 2.2 cm
875 g
1-year warranty
Keyboard
Bluetooth, 2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Wireless
Hot Keys Function
38 cm
15.8 cm
2.2 cm
875 g
White
AES-128
Google Chrome OS, Apple iOS 5.0 or later, Microsoft Windows 7 / 8 / 10 or later, Android 5.0 or later, Apple MacOS X 10.10 or later
AAA type
Installed Qty
2
Limited warranty - 1 year
Recommended Use: Office
Recommended Use: Leisure
Type: Keyboard
Colour: White
Compatibility: Mac
Compatibility: PC
Compatibility: Android
Brand: Logitech
