Logitech K750 Wireless Solar Powered Keyboard
Wireless Solar Keyboard K750
NO MORE BATTERIES - BUDGET SAVING SOLAR POWERED KEYBOARD!
Quicklinx: 7FH4WS00 Mfr#: 920-002929
The solar-powered wireless keyboard makes battery hassles a thing of the past in a streamlined, comfortable design.
If you've got light, You've got power
Good-bye, battery hassles. Solar power keeps your keyboard charged and ready - even indoors. Your desk is about to get sleeker thanks to this streamlined keyboard. It almost feels like typing on your laptop, but more comfortable.
Light-powered keyboard
It doesn't get more hassle-free than this. This keyboard charges itself whenever there's light--and stays charged for at least three months in total darkness--so you can say good-bye to battery hassles.
Only 1/3 -inch thick
With sleek lines and a thin profile, this stylish, streamlined keyboard adds style to your workspace--whether you've got a laptop or desktop.
Hand happiness
Treat your hands right with keys that feel good and make every keystroke comfortable, fluid and whisper-quiet.
Advanced 2.4 GHz wireless
So you can work or play in more places--like your comfy couch--the long-range wireless connection virtually eliminates delays, dropouts and interference.
Logitech Solar App
Want to know how much battery power you have? Or how much power you're getting from your desk lamp? The Logitech Solar App can help.
Logitech Unifying receiver
The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse or keyboard--without the hassle of multiple USB receivers.
Plug-and-play simplicity
Setup takes seconds--you simply plug the wireless receiver into a USB port on your computer and start using your keyboard right away without software.
Small steps, bright future
From the PVC-free construction to the fully recyclable box, this keyboard is designed to minimize its footprint.
  • Only 1/3 -inch thick
    With sleek lines and a thin profile, this stylish, streamlined keyboard adds style to your workspace-whether you've got a laptop or desktop
  • Plug-and-play simplicity
    Setup takes seconds-you simply plug the wireless receiver into a USB port on your computer and start using your keyboard right away without software
  • Logitech Solar App
  • Logitech Unifying receiver
    The tiny receiver stays in your laptop. Plus, you can easily add a compatible wireless mouse or keyboard-without the hassle of multiple USB receivers
  • Advanced 2.4 GHz wireless
    So you can work or play in more places-like your comfy couch-the long-range wireless connection virtually eliminates delays, dropouts and interference
  • Small steps, bright future
  • Powered by light
    Good-bye, battery hassles. Solar power keeps your keyboard charged and ready-even indoors
  • Very thin
  • Feels good
Logitech Wireless Solar K750 - keyboard - English Input Device
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
English
Logitech Unifying receiver, light-powered
43.21 cm x 15.7 cm x 0.71 cm
694.5 g
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
2.4 GHz
Wireless Receiver
Wireless
English
43.21 cm
15.7 cm
0.71 cm
694.5 g
Cleaning cloth
Microsoft Windows Vista / XP / 7
Shipping Width
48.5 cm
Shipping Depth
20 cm
Shipping Height
3.5 cm
Shipping Weight
1.068 kg
Limited warranty - 3 years
