With the subtle, ergonomically designed shape of Logitech Wireless Keyboard K350 your hands know precisely where to go. Your fingers naturally tuck into the Wave sculpted keys. The contoured palm rest keeps your hands cradled in comfort. And you won't have to relearn typing on an unfamiliar layout.
Wave design with constant curve layout
Guides hands into just the right position and conforms naturally to your fingers. You'll type with ease and confidence, but without having to re-learn typing on an unfamiliar layout. -
Cushioned palm rest
Helps position hands comfortably and properly on the keyboard. -
Logitech unifying receiver
The tiny wireless receiver stays in your notebook. There's no need to unplug it when you move around, so your keyboard is always connected when and where you feel like using it. Plus, you can easily add a compatible mouse or number pad - without the hassle of multiple USB receivers. -
Logitech Advanced 2.4 GHz wireless connectivity
You get the reliability of a cord plus cordless convenience and freedom - fast data transmission, virtually no delays or dropouts, and 128-bit AES encryption.
- Logitech Wireless Keyboard K350 - keyboard - UK - black Input Device
- Keyboard - ergonomic
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Hot Keys Function
- Multimedia, programmable, volume
- Palm rest, Logitech Unifying receiver, height-adjustable feet
- Black
- Microsoft Certification
- Compatible with Windows 7
- Interface
- 2.4 GHz
- Wireless Receiver
- Wireless
- Hot Keys Function
- UK
- Black
- Cables Included
- 1 x USB extension cable
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows Vista / XP / 7
- AA type
- Installed Qty
- 2
