Logitech K300 Compact Keyboard - USB
Compact Keyboard K300
Quicklinx: 6JNSWS00 Mfr#: 920-001488
Control your media and smarten up your space with the Logitech® Compact Keyboard K300. Its stylish, backlit media controls provide an elegant and easy way to access to your music, videos and e-mail, with keys that blend cleanly into the streamlined styling. The K300 features a space-saving design with full-size keys that frees up space on your desk - and makes the keyboard easy to store or take with you. A full-size, integrated number pad makes data entry fast and effortless. The ultra-flat profile helps you type comfortably with keys move quietly and feel great, shifting your wrists toward a more neutral position. Plus, setup is easy: the K300 works right out of the box, with no software to install.
  • Backlit media controls
    Access your music, videos, and e-mail with keys that blend cleanly into the streamlined styling.
  • Full-size number pad
    When it's time to crunch numbers, a full-size number pad makes data entry fast and effortless.
  • Easy setup
    The keyboard works right out of the box, with no software to install.
  • Space-saving design
    The compact design frees up space on your desk yet retains just enough room for full-size keys.
  • Ultra-flat profile
    The low-profile keys move quietly and feel great, while the ultra-flat design shifts your wrists toward a more neutral position.
Logitech Compact K300 - keyboard - UK
Keyboard
Backlit
USB
Wired
Localization and Layout
Hot Keys Function
Multimedia, e-mail
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
Backlit
USB
Input Device
Hot Keys Function
Multimedia, e-mail
Region
United Kingdom
1 x USB cable
Microsoft Windows Vista / XP
Limited warranty - 3 years
