Logitech K270 Wireless Keyboard
Quicklinx: 7WRHWS00 Mfr#: 920-003745
Recommended Use: Mobile, Leisure
Type: Keyboard
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
More than 50 In Stock
£24.93 ex VAT
£29.91 inc VAT
Reliable wireless - wherever you use your keyboard - thanks to the Logitech Unifying receiver that pairs with up to six Unifying-compatible mice and keyboards.
  • Logitech Unifying receiver
    The tiny wireless receiver stays in your laptop-there's no need to unplug it when you move around-and connects your keyboard
  • Advanced 2.4 GHz wireless
    So you can work or play in more places-like your comfy couch-the wireless connection virtually eliminates delays, dropouts and interference and gives you range of up to 10 meters (33 feet)
  • 24-month battery life
    You'll enjoy less hassle with a battery life of up to 24 months. Auto standby helps you save energy
  • Eight hot keys
    The things you do most are right at your fingertips with eight hot keys for instant access to the Internet, e-mail, play/pause, volume and more
  • Plug-and-play simplicity
    Setup takes seconds-you simply plug the wireless receiver into a USB port on your computer and start using your keyboard right away without software
  • Full-size layout
    The sleek keyboard saves you space without sacrificing comfort thanks to the familiar, full-size layout-including number pad-and wide, curved space bar
  • Spill-resistant keyboard
    Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills
  • Logitech reliability
    You get the high quality and reliability that's made Logitech a global leader for keyboards at a price you can afford-plus a 3-year limited hardware warranty
  • Durable, UV-coated keys
    The special coating protects the keys from fading so you can see what you're typing for years to come
  • Connect with ease
    You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it. Learn more about the Logitech Unifying receiver
  • Just one touch
    You can do more, faster with eight hot keys for instant access to music, e-mail and more
  • Charged and ready
    With intelligent power management, you can go years without replacing the batteries
Logitech Wireless Keyboard K270 - keyboard - UK Input Device
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
Hot Keys Qty
8
Hot Keys Function
Internet browsing, e-mail, volume, play/pause
Logitech Unifying receiver, spill-resistant
Microsoft Certification
Compatible with Windows 7
Keyboard
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Wireless
Hot Keys Qty
8
Hot Keys Function
Plug and Play
Microsoft Windows Vista / XP / 7
AAA type
Installed Qty
2
Recommended Use: Leisure
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
