Reliable wireless - wherever you use your keyboard - thanks to the Logitech Unifying receiver that pairs with up to six Unifying-compatible mice and keyboards.
The tiny wireless receiver stays in your laptop-there's no need to unplug it when you move around-and connects your keyboard -
Advanced 2.4 GHz wireless
So you can work or play in more places-like your comfy couch-the wireless connection virtually eliminates delays, dropouts and interference and gives you range of up to 10 meters (33 feet) -
24-month battery life
You'll enjoy less hassle with a battery life of up to 24 months. Auto standby helps you save energy -
Eight hot keys
The things you do most are right at your fingertips with eight hot keys for instant access to the Internet, e-mail, play/pause, volume and more -
Plug-and-play simplicity
Setup takes seconds-you simply plug the wireless receiver into a USB port on your computer and start using your keyboard right away without software -
Full-size layout
The sleek keyboard saves you space without sacrificing comfort thanks to the familiar, full-size layout-including number pad-and wide, curved space bar -
Spill-resistant keyboard
Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills -
Logitech reliability
You get the high quality and reliability that's made Logitech a global leader for keyboards at a price you can afford-plus a 3-year limited hardware warranty -
Durable, UV-coated keys
The special coating protects the keys from fading so you can see what you're typing for years to come -
Connect with ease
You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it. Learn more about the Logitech Unifying receiver -
Just one touch
You can do more, faster with eight hot keys for instant access to music, e-mail and more -
Charged and ready
With intelligent power management, you can go years without replacing the batteries
- Logitech Wireless Keyboard K270 - keyboard - UK Input Device
- Keyboard
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Hot Keys Qty
- 8
- Hot Keys Function
- Internet browsing, e-mail, volume, play/pause
- Logitech Unifying receiver, spill-resistant
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Keyboard
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Wireless Receiver
- Wireless
- Hot Keys Qty
- 8
- Hot Keys Function
- UK
- Plug and Play
- OS Required
- Microsoft Windows Vista / XP / 7
- AAA type
- Installed Qty
- 2
- Limited warranty - 2 years
