Logitech K120 Keyboard - Swiss Layout
Quicklinx: HH8VWS00 Mfr#: 920-002504
Wired / Wireless: Wired
Compatibility: PC
33 In Stock
£11.11 ex VAT
£13.33 inc VAT
A USB keyboard that gives you a better typing experience that's built to last.
  • RELIABLE SIMPLICITY
    Getting things done should be simple. That's what makes this full-sized keyboard the right fit. It's a reliable and durable partner equipped with a number pad with an easy-to-use design that works right out of the box. Just plug in this corded keyboard via USB and go
  • COMFORTABLE AND FULL-SIZE
    This full-size keyboard with integrated number pad makes data entry, calculations and navigation a breeze. The curved space bar along with easy-to-read keys provide a comfortable and familiar typing experience
  • EASY PLUG & PLAY
    The keyboard works right out of the box. Just plug into the USB port, and it's ready to go. No downloads, no setup, no fuss
  • DURABLE AND SPILL-RESISTANT
    Spill-resistant design, durable keys and sturdy tilt legs with adjustable height, this keyboard is built to last
  • BUILT TO KEEP GOING
    K120 is built with the same high quality and reliability standards that have made Logitech the #1 global leader for mice and keyboards
  • TYPING FEEL YOU LOVE
    This stable keyboard delivers a familiar typing feel, with deep-profile keys, and a springy, responsive bounce-back
Logitech K120 - keyboard - Swiss Input Device
Keyboard
USB
Wired
Localization and Layout
Swiss
Spillproof
45 cm x 15.5 cm x 2.4 cm
0.55 kg
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
USB
Swiss
Spillproof
45 cm
15.5 cm
2.4 cm
0.55 kg
1 x USB cable - 1.5 m
Plug and Play, UL, TUV, VCCI, BSMI, cUL, FCC, KCC, WEEE
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7
Limited warranty - 3 years
Compatibility: PC
Brand: Logitech
