Logitech K120 for Business Keyboard - US International
Quicklinx: DLXQWS00 Mfr#: 920-002479
Recommended Use: Office
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: PC
£10.82 ex VAT
£12.98 inc VAT
With low-profile keys, a standard layout and a sleek yet sturdy design, this budget-friendly USB keyboard is built to last.
Your hands will enjoy the low-profile, virtually silent keys and standard layout with full-size F-keys and number pad.
The slim keyboard isn't just sleek - it's tough with a spill-resistant design, sturdy tilt legs and durable keys.
You'll be ready for business in no time with this Plug-and-Play keyboard - no software needed.
  • Comfortable, quiet typing
    You'll enjoy a comfortable and quiet typing experience thanks to the low-profile keys that barely make a sound to minimize distractions.
  • Industry standard key layout
    You get a layout you're used to with full-size F-keys to make things easier if you use keyboard templates.
  • Spill-resistant design
    Liquid drains out of the keyboard, so you don't have to worry about ruining your investment with accidental spills.
  • Thin profile
    The keyboard has a thin profile that adds a sleek look to your desk while keeping your hands in a more comfortable, neutral position.
  • Durable keys
    The keys can last up to 10 million keystrokes so you can keep typing long after many keyboards have called it quits.
  • Sturdy, adjustable tilt legs
    You can extend the sturdy folding legs to increase the keyboard tilt by 8 degrees to address your personal ergonomic needs.
  • Plug-and-Play USB connection
    Simple setup saves you time and resources - you just plug it into a USB port and start using it right away without software.
  • Easy-to-read keys
    The bold, bright white characters make the keys easier to read -perfect for those with less-than-perfect vision. They're less likely to wear off, too.
  • Logitech reliability
    You get the high quality and reliability that's made Logitech the global leader for keyboards and mice at a price you can afford.
  • Curved space bar
    It keeps your hands in a more natural position so you can type in greater comfort.
Logitech K120 for Business - keyboard - US International Input Device
Keyboard
USB
Wired
Localization and Layout
US International
Spillproof
45 cm x 15.5 cm x 2.4 cm
0.55 kg
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
USB
US International
Region
United States
Spillproof
45 cm
15.5 cm
2.4 cm
0.55 kg
1 x USB cable - 1.5 m
Plug and Play, UL, TUV, VCCI, BSMI, cUL, FCC, KCC, WEEE
Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7
Limited warranty - 3 years
Type: Keyboard
Colour: Black
Compatibility: PC
Brand: Logitech
