Logitech Illuminated K740 - UK Layout
Quicklinx: B0KQWS00 Mfr#: 920-005694
Logitech Illuminated Keyboard K740 is a slim, elegant keyboard with backlit keys and a soft-touch palm rest to type comfortably - even in the dark.
  • LOGITECH PERFECTSTROKE KEY SYSTEM
    The PerfectStroke key system distributes typing force evenly across the key surfaces making every keystroke quiet, natural and fluid-even if you strike the edge of a key
  • BETTER TYPING-DAY OR NIGHT
    Convenient typing in low light or in the dark. The illuminated keys are sharp, bright and easy to read
  • COMFORTABLE AND QUIET
    Whisper-quiet, comfortable typing with the Logitech Perfectstroke key system and a built-in, soft-touch palm rest
  • SOFT-TOUCH PALM REST
    The built in palm rest has a soft, rubber coating for enhanced comfort. Your hands should move freely and be elevated above the palm rest while you type. In between typing, use the palm rest as a resting place for your wrists. Placing the keyboard flat on the desk helps to keep your wrists in a more neutral (straight) position, but you can also use the tilt legs to adjust the height to suit you
  • ELEGANTLY DESIGNED
    The keyboard is classic black with a touch of orange to identify the FN functions. A clear transparent strip borders the left, top and right edges and a complementary strip of glossy black separates the keys and the palm rest. Embedded in the glossy black strip, to the right of the keyboard, you will find the Num Lock, Caps Lock and Scroll lock LEDs.Together, these elements add a touch of elegance to your desk
  • FULL-SIZE LAYOUT
    The keyboard has a full size layout with a number pad and full size arrow keys to navigate your document easily
Logitech Illuminated K740 - keyboard - UK - orange, classic black Input Device
Keyboard
Backlit
USB
Wired
Localization and Layout
Hot Keys Function
Internet browsing, multimedia, e-mail, volume
PerfectStroke, built-in wrist rest, adjustable brightness, height-adjustable feet
Orange, classic black
3-year warranty
Keyboard
Backlit
USB
Hot Keys Function
USB cable - 1.8 m
Included Software
Logitech SetPoint
Microsoft Windows Vista / XP / 7 / 8
Limited warranty - 3 years
