An iPad Air case that adjusts to you. Get comfy, Hinge holds iPad at any angle within a 50-degree range. iPad stays firmly in place until you decide to change it.
Flexible and durable
A smooth-gliding hinge makes the case flexible yet durable. Withstands angle adjustments time after time -
Multi-angle stand - adapts to you
Hinge precisely sets to any angle within a 50 degree range and holds firmly once in place -
Easy sharing
Flip the iPad case to instantly share your screen with coworkers, family or friends -
Stylish fabric
Beautiful fabric perfectly fits your style whether you're at home or on-the-go -
Essential Protection System
Precision engineered with state-of-the-art materials and cutting-edge manufacturing, Hinge protects iPad from accidental bumps, scratches and spills. Scratch protection for iPad enabled when case cover is closed -
Camera, microphone and charger holes
Use the camera, microphone and charger without removing iPad from the case
- Logitech Hinge - protective case
- Product Type
- Protective case
- 17.56 cm x 1.45 cm x 24.48 cm
- 335 g
- Material
- Polyester
- Light brown
- 2-year warranty
- 17.56 cm
- 1.45 cm
- 24.48 cm
- 335 g
- Material
- Polyester
- Light brown
Carrying Case
- Protective case
- Protection
- Scratch-resistant, spill-resistant
- Camera lens cutout, sleeping mode, port cut-outs, adjustable viewing angles
- 2 years
