Logitech HD Webcam C525
HD Webcam C525
Quicklinx: 7SN8WS00 Mfr#: 960-000721
With HD 720p video calling and recording, as well as one-click HD uploading to Facebook, now you can share your HD world - anywhere, anytime.
  • HD video calls
    You'll get HD 720p video calling on most major instant messaging services
  • Premium autofocus
    Your images stay razor sharp, even in close-ups (up to 7 cm from the camera lens) with built-in autofocus
  • Fold-and-go, plus-swivel design
    It's easy to slip it into your bag and take it with you. Plus, the 360-degree, full-rotational design makes calling and recording easier at any angle
  • 8-megapixel snapshots
    You can take high-resolution snapshots at up to 8 megapixels (software enhanced)
  • Built-in mic with noise reduction
    It gives you clear conversations without annoying background noise
  • Auto light correction
    Even if you make a video call in dim or poorly backlit settings, the camera will intelligently adjust to produce the best possible image
  • IM compatibility
    Works with Skype , Google Hangouts , Yahoo! Messenger, and other popular instant messaging applications
  • HD 720p video calls
    Enjoy widescreen HD video (720p) on most major IMs that support HD video calls
  • Get closer with autofocus
    You'll enjoy razor-sharp video calls even in extreme close-ups (up to 7 cm)
  • Goes where you go
    Slip it in your bag, purse, even your pocket-with its fold-and-go design, this webcam goes wherever you go
Logitech HD Webcam C525 - webcam
Webcam
Audio
Yes: built-in microphone
Wired
Camera
Max Resolution
1280 x 720
Focus Adjustment
Automatic
USB 2.0
1 - USB cable - 1.5 m
USB 2.0 compatibility, 720p HD movie recording, RightSound technology, RightLight 2 technology, 720p HD video calls, Logitech Fluid Crystal Technology
Microsoft Certification
Compatible with Windows 7
Webcam
Audio Support
Wired
Western Europe
Camera
Max Digital Video Resolution
1280 x 720
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB 2.0
Interfaces Details
1 x USB 2.0 - 4 pin USB Type A
1 x USB cable - 1.5 m
Software Included
Drivers & Utilities, Logitech Video Effects, Logitech Vid HD
Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista
System Requirements Details
Windows XP/Vista/7 - 1 GHz - RAM 512 MB - HD 200 MB
