Sharing, socializing, connecting with the people you care about - that's what makes a webcam different. And Logitech HD webcams are about sharing your life - but bigger, better, brighter, smoother. High-def yourself.
HD 720P VIDEO CALLS IN A STURDY DESIGN
C310 HD Webcam gives you sharp, smooth video calling (720p/30fps) in a widescreen format. Automatic light correction for clearer, better conference calls -
WIDESCREEN HD 720P VIDEO CALLS
Crisp HD 720p/30 fps video calls with 60° diagonal field of view and auto light correction. Compatible with popular platforms including SkypeTM and Zoom -
MONO NOISEREDUCING MIC
The built-in noise-reducing mic makes sure your voice comes across clearly up to 1.5 meters away, even if you're in busy surroundings -
AUTO-LIGHT CORRECTION
C310's RightLightTM 2 feature adjusts to lighting conditions, producing brighter, contrasted images to help you look good in all your conference calls -
FIRM MOUNTING OPTION
The adjustable universal clip lets you attach the camera securely to your screen or laptop, or fold the clip and set the webcam on a shelf -
ESSENTIAL TOOLS. BETTER WORK
Simple, powerful tools that deliver real work victories - even at home. Complete your setup with the right keyboard, mouse, headset, and webcam for better typing and navigation, plus superior audio and video-so you can conquer just about any task from home
- Logitech HD Webcam C310 - webcam
- Webcam
- Audio
- Yes: built-in microphone
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1280 x 720
- Motion Detection
- USB 2.0
- Cables Included
- 1 - USB cable - 1.5 m
- RightSound technology, RightLight 2 technology, snap-shot button, Motion Detection Technology, 720p HD video calls, noise reduction, Skype compatible
- 2-year warranty
- Webcam
- Audio Support
- Wired
- Localisation
- EMEA
Camera
- Max Digital Video Resolution
- 1280 x 720
- Motion Detection
- Computer Interface
- USB 2.0
- Cables Included
- 1 x USB cable - 1.5 m
- Software Included
- Drivers & Utilities, Logitech Video Effects, Logitech Vid HD
- OS Required
- Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits), Windows 8
- System Requirements Details
- Windows Vista/7/8 - 1 GHz - RAM 512 MB - HD 200 MB
- Limited warranty - 2 years
