Logitech HD Webcam C310
Quicklinx: FW86WS00 Mfr#: 960-001065
Compatibility: PC
Interface: USB
29 In Stock
£21.34 ex VAT
£25.60 inc VAT
Sharing, socializing, connecting with the people you care about - that's what makes a webcam different. And Logitech HD webcams are about sharing your life - but bigger, better, brighter, smoother. High-def yourself.
  • HD 720P VIDEO CALLS IN A STURDY DESIGN
    C310 HD Webcam gives you sharp, smooth video calling (720p/30fps) in a widescreen format. Automatic light correction for clearer, better conference calls
  • WIDESCREEN HD 720P VIDEO CALLS
    Crisp HD 720p/30 fps video calls with 60° diagonal field of view and auto light correction. Compatible with popular platforms including Skype and Zoom
  • MONO NOISE-REDUCING MIC
    The built-in noise-reducing mic makes sure your voice comes across clearly up to 1.5 meters(5 ft) away, even if you're in busy surroundings
  • AUTO-LIGHT CORRECTION
    C310's RightLight 2 feature adjusts to lighting conditions, producing brighter, contrasted images to help you look good in all your conference calls
  • FIRM MOUNTING OPTION
    The adjustable universal clip lets you attach the camera securely to your screen or laptop, or fold the clip and set the webcam on a shelf
Logitech HD Webcam C310 - webcam
Webcam
Audio
Yes: built-in microphone
Wired
Camera
Max Resolution
1280 x 720
Motion Detection
USB 2.0
1 - USB cable - 1.5 m
RightSound technology, RightLight 2 technology, snap-shot button, Motion Detection Technology, 720p HD video calls, noise reduction, Skype compatible
Webcam
Audio Support
Wired
EMEA
Camera
Max Digital Video Resolution
1280 x 720
Motion Detection
Computer Interface
USB 2.0
1 x USB cable - 1.5 m
Software Included
Drivers & Utilities, Logitech Video Effects, Logitech Vid HD
Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits), Windows 8
System Requirements Details
Windows Vista/7/8 - 1 GHz - RAM 512 MB - HD 200 MB
Compatibility: PC
Interface: USB
Brand: Logitech
