Logitech HD Pro Webcam C920
Quicklinx: FW84WS00 Mfr#: 960-001055
Compatibility: Mac, PC
Interface: USB
£71.16 ex VAT
£85.39 inc VAT
Full HD 1080p video that's faster, smoother and works on more computers.
  • VIDEO CALLS IN FULL HD CLARITY
    C920 delivers remarkably crisp and detailed Full HD video (1080p at 30fps) with a full HD glass lens, 78° field of view, and HD auto light correction-plus dual mics for clear stereo sound. Everything you need to look great in conference calls and record polished demos
  • GREAT VIDEO CALLS. EVEN AT HOME
    Make a strong impression in your video conference calls with a diagonal, fixed 78° field of view to perfectly frame you and your space-plus full HD at 1080p/30fps or 720p/30fps. The five-element glass lens captures razor-sharp images and clear colors, while autofocus adjusts smoothly and precisely for consistent definition and fluid video
  • DUAL-MIC STEREO AUDIO
    Two microphones, one on either side of the camera, capture more realistic sound from a broader range of angles-so your voice comes through sounding natural and clear in conference calls
  • ALL-IN-ONE CONTENT CREATION WITH CAPTURE
    Easily create, record, and customize settings with our Capture app. A suite of features lets you fully edit and customize your stream, so you can add transitions and text overlays, customize webcam settings, and more
  • OPTIMAL LIGHTING
    Equipped with automatic HD light correction, the C920 uses Logitech's RightLightTM 2 technology to adjust to your lighting conditions, producing bright, contrasted images, even if you're in a dim setting
  • FULL HD GLASS LENS
    The full HD five-element glass lens and premium autofocus capture razor-sharp, clear images, adjusting smoothly and precisely to provide consistent high definition in conference calls
Logitech HD Pro Webcam C920 - webcam
Webcam
Audio
Yes: built-in stereo microphone
Wired
Camera
Max Resolution
1920 x 1080
Focus Adjustment
Automatic
USB 2.0
1 - USB cable - integrated - 1.5 m
720p HD video calls, Carl Zeiss optics, Logitech Fluid Crystal Technology, 1080p Full HD video calling on Skype, 1080p Full HD movie recording, Skype compatible
Microsoft Certification
Compatible with Windows 7
Webcam
Audio Support
Wired
Camera
Digital Video Format
H.265
Max Digital Video Resolution
1920 x 1080
Lens Construction
Focus Adjustment
Automatic
Computer Interface
USB 2.0
1 x USB cable - integrated - 1.5 m
Software Included
Logitech Vid HD
Microsoft Windows 7 64-bit Edition, Google Chrome OS, Microsoft Windows Vista / 7 / 8 / 10
Compatibility: Mac
Compatibility: PC
Interface: USB
Brand: Logitech
