Logitech Harmony Ultimate
Quicklinx: 9CQKWS00 Mfr#: 915-000203
Harmony Ultimate gives you all the control you deserve. Control home theater devices behind closed cabinets and walls. Access IR devices as well as Bluetooth game consoles. Even use your mobile phone as a powerful, personal universal remote control.
Exclusive to Harmony Ultimate are unique features that make it especially powerful. Double the number of buttons by programming them for both short and long presses. See in dark rooms thanks to the tilt sensors that automatically light up the touch screen. And gentle vibrations let you know when a screen button is pressed, so there's no need to take your eyes off whatever you're watching.
  • The ultimate control
  • Control Philips Hue lights
    With one touch of your Harmony Ultimate, you can dim your lights, turn on your TV, start your DVD and set the mood. Harmony Ultimate allows you to set your Hue lights to the perfect brightness and color for any activity.
  • Harmony Ultimate control features
  • Customizable touch screen
    The vibrant, 2.4" color touch screen lets you swipe and tap to change channels, adjust the volume, fast-forward or rewind. Or you can customize it the way you want. Plus you can personalize your list of favorite channels and switch to them with one tap.
  • Power only Harmony can provide
    Harmony Ultimate can control up to 15 devices and is compatible with over 225,000 home theater devices. And unique to Harmony is our patented Smart State technology, which remembers your devices' power and input settings and automatically adjusts them based on what you want to do.
Logitech Harmony Ultimate universal remote control
Universal remote control
Infrared
Supported Device Qty
15
Supported Devices
Game console, TV / AV System
Input Device
Keypad, touch screen
Wireless Technology
IEEE 802.11b/g/n, Bluetooth
Display
LCD 2.4"
Remote control unit battery rechargeable
Infrared
Wireless Technology
15
Supported Devices
Input Device
Back-lit buttons, rechargeable
Display
Display
LCD 2.4"
Colour Display
Connector Type
1 x USB (4 PIN USB Type A)
Operating System
MS Windows XP, MS Windows 7, MS Windows Vista, Apple MacOS X 10.4.8 or later, Windows 8, Android 2.3 or later, iOS 5.0 or later
1 x USB cable - external
USB cable, remote control charging stand, 2 AC power adapters, 2 IR Blasters, Harmony Hub
9CQK C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
