The Logitech Wireless Headset H820e, combines enterprise-quality wireless audio with superior design elements, making it LogitechK's best wireless headset. Interruptions are minimized with a distinct in-call LED light, and muting is intuitive thanks to the on boom mute button and LED mute indicator light.
WIRELESS FOR GREATER FREEDOM
The Logitech H820e Headset stays connected within 100 meters of your desk, with up to 10 hours of wideband talk time. The headset's DECT wireless connectivity won't interfere with Wi-Fi devices in your office -
ALL-DAY COMFORT
Enjoy comfort and style. The lightweight, contemporary design of the H820e Headset is complemented by top-quality materials like TR90 nylon, a padded leatherette headband, and replaceable leatherette ear pads to provide many hours of comfort and durability -
IDEAL FOR BUSY OFFICES
Phone calls in active work environments can be difficult. The H820e Headset is designed for these situations. The headset automatically pairs with any H820e dock – ideal for hot desking. An LED lets others know you're on the phone, while a visual indicator tells you when you have an incoming call -
DESIGNED FOR BUSINESS
The H820e Headset is certified for use with leading conference software applications such as Skype for Business and Cisco Jabber . H820e is recommended for heavy-duty business users in open workspaces, offices, or home offices. Choose H820e Mono or H820e Dual for one or two speakers -
YES, I'M ON A CALL
Located on the backside of the boom, an LED indicator provides a visual alert to those behind you that you are on a call, preventing accidental disturbances during calls -
NOISE & ECHO CANCELLATION
With acoustic echo cancellation and a noise-cancelling microphone, H820e is optimized so you can hear and be heard, even in noisy workspaces -
AUTOMATIC PAIRING
H820e headsets automatically pair when placed in any H820e charger dock, making it easy to use the headsets with any workstation in large deployment or hot desking situations -
CONVENIENT CONTROLS
Control the call with on-ear answer/end 1 and volume up/ down buttons. The raised button design provides a point of reference for your fingers so you can feel the buttons you're pressing. Mute and unmute with a tactile button on the adjustable boom -
HEAR SAFELY
Logitech Sound Protection protects against sounds above 115 dBA to deliver exceptional listening comfort for voice and music; compliant with EN60950-1 -
WELL-MANNERED WIRELESS
DECT spectrum wireless connectivity provides exceptional wireless range that won't interfere with Wi-Fi devices in your office. An option to switch between wide and narrow band improves performance in areas of high-density deployment and extends talk time
- Logitech Wireless Headset Mono H820e - headset
- Product Type
- Headset - DECT - wireless
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear monaural
- Connectivity Technology
- Wireless
- Wireless Technology
- DECT
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 150 - 7000 Hz - Sensitivity 103 dB
- Microphone
- Boom
- Controls
- Mute, volume, answer/end
- 2-year warranty
- Product Type
- 17.4 cm
- 5 cm
- 16.5 cm
- 88 g
- Recommended Use
- Computer
- Max Operating Distance
- 100 m
Audio Output
- On-ear monaural
- Headphones Cup Type
- Open
- Wireless
- DECT
- Sound Output Mode
- Mono
- 150 - 7000 Hz
- Sensitivity
- 103 dB
Microphone
- Boom
- Sensitivity
- -45 dB
- 100 - 7000 Hz
- Total Harmonic Distortion (THD)
- 10%
Remote Control
- Controls
Wireless Link
- Transmission Range
- 100 m
- Connector Type
- USB (4 PIN USB Type A)
- Included Accessories
- Charging stand
- Cable Details
- USB charge cable
- Battery
- Headphone battery
- Run Time (Up To)
- 10 hour(s)
- Limited warranty - 2 years
