The Logitech H570e headset offers a reliable and comfortable solution for communication needs, suitable for both office settings and home use. With its boom microphone and noise-canceling capabilities, this headset ensures clear audio during calls, promoting productivity and collaboration. The adjustable headband and on-ear design provide a comfortable fit, while the leatherette earpads enhance your listening experience.
Featuring convenient in-cord volume control and mute functions, the Logitech H570e allows users to manage audio effortlessly. The dynamic equalizer and acoustic echo cancellation improve sound quality, making conversations more natural. With a 1.9 m headset cable and USB connectivity, this headset is compatible with both Mac and Windows systems, ensuring integration into various computer setups.
Affordable clarity, certified for business
Enjoy clear audio on calls and in video meetings with Logitech H570e, a wired headset with noise-canceling features at a great price. Certified for business and now available in a Microsoft Teams version, H570e is made for the enterprise -
CERTIFIED FOR BUSINESS
Logitech H570e is a hard-working business headset available in two versions - a Microsoft Teams-certified version with full Teams functionality, and a UC version that's certified for Works With Chromebook and compatible with Cisco for audio -
CRYSTAL-CLEAR CALL QUALITY
Employees enjoy clear audio with noise-canceling mic, acoustic echo cancellation, and digital signal processing (DSP) to block out unwanted noise. The headset features a 30 mm audio driver with dynamic EQ, delivering the best sound quality for what the user is listening to -
EFFORTLESS CONTROLS FOR CALLS
Easy, fast inline controls let you answer/end calls, adjust volume up/down, mute/unmute calls - everything at your fingertips. Convenient light indicators provide a quick visual of call status. The Microsoft Teams version features a dedicated Teams button with quick access to Teams activities -
A choice you can feel good about
H570e is designed with sustainability in mind. It features replaceable leatherette earpads that extend the product life. Additionally, the Microsoft Teams version is made with a minimum 45% post-consumer recycled plastic in the plastic parts, and shipped in FSC -certified packaging -
Lightweight comfort
Lightweight and durable, the H570e headset delivers comfort day after day. Padded headband with metal reinforcement provides strength and flexibility, with a fit that feels just right. Easily switch the headset to put the mic on the right or left -
Easy management & personalization
The Microsoft Teams version of the H570e headset is supported by Logitech Sync, which allows IT to remotely manage the headset and other Logitech devices. Employees can also customize the Teams version headset with Logi Tune for a personalized experience -
Listen safely
Compliant with EN 50332-2, the H570e headset guards against sounds above 100 dBA, delivering exceptional listening comfort for calls and music. The Microsoft Teams version also offers anti-startle protection, which prevents sudden sound peak during a call -
Connect and go
Instantly connect your H570e headset to the USB port on a Mac or PC for plug-and-play simplicity. No drivers required for installation -
Remain aware of your surroundings
The mono version of H570e, which covers only one ear, allows users to more easily hear sounds around them. For personal or work-related reasons, some people want to remain more aware of their surroundings while wearing their headsets
- Logitech H570e - headset
- Product Type
- Headset - wired - USB-C
- Compatibility
- Windows, Mac, Chrome OS
- Recommended Use
- Computer - communication
- Additional Functions
- DSP
- Localisation
- Europe, Middle East, Africa
- Headphones Form Factor
- On-ear binaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Dynamic equaliser
- Audio Specifications
- Frequency Response 20 - 20000 Hz - Sensitivity 95 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional, omni-directional
- Microphone Noise Cancelling
- Microphones Included
- 2
- Controls
- Answer/end, reject call, volume, mute, Microsoft Teams button
- Software Certification
- Certified for Microsoft Teams
- 2-year warranty
- Product Type
- Compatibility
- DSP
- 15.7 cm
- 5 cm
- 17.1 cm
- 113 g
- Body Material
- 54% post-consumer recycled plastic
- Earpad Material
- Leatherette
- Recommended Use
- Acoustic echo cancellation, in-call LED indicator
- Protection
- Hearing protection, acoustic shock protection
- Localisation
Audio Output
- On-ear binaural
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Dynamic equaliser
- 20 - 20000 Hz
- Sensitivity
- 95 dB
- Impedance
- 32 Ohm
- Max Sound Pressure
- 98 dB
- Diaphragm
- 30 mm
- In-Cord Volume Control
- Adjustable Headband
- Volume Limiting Function
- Audio Output Details
- Multimedia - 20 - 20000
Microphone
- Boom
- Form Factor
- Headset microphone
- 2
- 100 - 8000 Hz
- Noise Cancelling
Remote Control
- Controls
- Connector Type
- USB (24 pin USB-C)
Cable
- Cable Length
- 1.9 m
- Cable Details
- Headset cable - 1.9 m
- EN 50332-2, FSC, Plug and Play
- Limited warranty - 2 years
- Shipping Width
- 16.3 cm
- Shipping Depth
- 6.2 cm
- Shipping Height
- 17.4 cm
- 10 °C
- 45 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
