Now it's easy to make and receive Skype calls: just plug in your Logitech USB Headset H330 and you're ready to go.
Digital USB connection
No hassles - just plug and play to experience digitally enhanced audio and premium sound clarity. -
Stereo sound
Why stop at Internet calls? Your stereo headset is ready for music and movies, too. -
Noise-canceling microphone
You won't have to compete with background noise to be heard. -
Rotating adjustable boom
It allows precise positioning. Microphone rotates out of the way when you don't need it. -
Works with most popular Internet calling applications
Just plug it in, and start using with most applications, including Skype, Yahoo!, Windows Live, and AIM.
- Logitech USB Headset H330 - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Headphones Form Factor
- On-ear binaural
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 50 - 15000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- 2-year warranty
- Product Type
- Headset - wired
- Recommended Use
- Computer
Audio Output
- On-ear binaural
- Wired
- Sound Output Mode
- Stereo
- 50 - 15000 Hz
Microphone
- Boom
- Mono
- Sensitivity
- -44 dBV/Pascal
- 100 - 10000 Hz
- Connector Type
- USB (4 PIN USB Type A)
- Cable Details
- USB cable - 2 m
- Limited warranty - 2 years
