Logitech GROUP Conference Camera
Suitable for conferences of up to 14 people!
Quicklinx: BY0RWS00 Mfr#: 960-001057
Type: Video Conference Kit
24 in stock
£794.98 ex VAT
£953.97 inc VAT
ConferenceCam solution for meetings with up to 14 participants.
Outstanding video conferences
Imagine a meeting where everyone is seen and heard. GROUP delivers this with exceptionally sharp video quality and a masterfully designed, full-duplex speakerphone.
Easy to deploy and use
Group video conferencing system is simple to set up and use. USB plug-and-play connections make video meetings easy.
Works with leading applications
Continue to work within your own computing environment. GROUP is compatible with most video software applications - including the ones you're already using.
Hassle-free meeting room bundle
The Logitech Group Kit with Intel® NUC, configured and validated for performance and compatibility with the VC apps you already use, provides a robust, easy-to-use video conferencing solution that is easy-to-buy and affordable for every room.
  • PERFECT FOR LARGER ROOMS
    GROUP, our video conferencing solution for rooms that seat 14–20 people, delivers high quality HD video and crystal clear audio, allowing any meeting place to be a video collaboration space. With advanced features like acoustic echo cancellation, noise reduction technology, and intuitive controls, it's easier than ever to include everyone in the conversation
  • PLUG-AND-PLAY SIMPLICITY
    USB plug-and-play connectivity makes GROUP a breeze to deploy and use. Simply connect GROUP the conference room computer or your laptop through USB, and you're good to go. Use GROUP with any video conferencing software, including those you already use. For great-sounding audio calls, pair your mobile device with Bluetooth wireless technology to the GROUP speakerphone
  • OPTIONS GIVE YOU VERSATILITY
    Customize the setup to match the layout and size of your room. Mount the camera on a table, tripod, or wall. Optional expansion mics extend audio coverage up to 28 feet (8.5 meters). Add an optional 33 feet (10 meter) or 49 feet (15 meter) cable to increase the reach of the speakerphone or camera
  • HIGH-DEFINITION VIDEO
    Bring meetings into focus with GROUP's premium lens, 10x lossless zoom, and HD 1080p/30 performance. Perfectly frame presenters and whiteboards with pan/tilt control, and zoom in for detail and clarity. GROUP's 90° field-of-view provides ideal coverage for medium and large conference rooms, with motorized pan and tilt for wall-to-wall, floor-to-ceiling coverage
  • NATURAL-SOUNDING AUDIO
    Everyone hears and can be heard with GROUP's full-duplex speakerphone, which delivers sound that's crisp, clear, and highly intelligible. Acoustic echo cancellation and noise reduction technology make conversations natural-sounding while reducing reverberation and ambient noise
  • Speakerphone with Bluetooth
    Hear and be heard with life-like clarity. GROUP's full-duplex speakerphone provides 360° coverage with four omnidirectional mics. Beamforming technology helps pick up speech throughout a 6m / 20 ft diameter while reducing keyboard clicks and other audible distractions. You can even pair GROUP with your smartphone or tablet to enjoy outstanding audio clarity and ample volume with mobile applications and conference calls
  • Certified for Business
    GROUP offers a plug-and-play USB connection to conference room computers, and is certified for Skype for Business, Microsoft Cortana , Cisco Jabber compatible, and offers enhanced integration with BlueJeans, Broadsoft, LifeSize Cloud, Vidyo, and Zoom. If your preferred application can recognize a webcam, you can use it with GROUP
  • Convenient Controls
    GROUP's speakerphone provides a convenient dock for the handheld remote control, and features an LCD status screen and tactile buttons to mute audio, adjust volume, move the camera, and more
  • Available Expansion Mics
    Extend the range of the GROUP video conferencing system with Logitech GROUP Expansion Mics. Accommodate up to 20 people in one large room and make sure everyone's voice can be heard. Simply plug the microphones into the GROUP speakerphone: they are automatically recognized and configured. An indicator light shows when the microphone is muted, when a call is active, and when Bluetooth wireless pairing has begun
  • Mute with Confidence
    With tactile mute buttons on the speakerphone, handheld remote, and optional expansion mics, GROUP makes it easy to assure your privacy. When muted, GROUP's LED status ring lights up red, a subtle yet obvious assurance that's easily seen throughout the room
  • Cabling Made Easy
    GROUP's compact Hub simplifies cabling and makes it easy to run cables under tables and through conduit. Integrated data and power means that the camera and speakerphone each connect with a single cable. The included 5m / 16 ft cables give you lots of placement options, while optional extended cables offer double or triple the reach
  • Field Upgradeable
    With regular firmware updates, Logitech continuously improves the GROUP video conferencing experience. For example, recent updates delivered substantial improvements to automatic echo cancellation and gain control, plus upgraded beamforming and duplex performance. It's another reason why Logitech delivers the best value proposition in the industry
Logitech GROUP - video conferencing kit
Video conferencing kit
Video Input
Digital camera
Audio Input
Microphone
Audio Output
Speaker(s)
Input Device
Remote control
Network adapter - Bluetooth, NFC
Google Chrome OS, Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8.1 / 10
Dimensions & Weight Details
Speakerphone - Width 24 cm Depth 24 cm Height 6.5 cm Weight 1.223 kg , Camera - Width 13 cm Depth 13.8 cm Height 17 cm Weight 585 g , Hub - Width 9.4 cm Depth 7.4 cm Height 3.4 cm Weight 83 g , Remote - Width 5 cm Depth 12 cm Height 1.2 cm Weight 51 g
Video Input
Digital camera (colour) - external
Digital Video Capture Resolution
1920 x 1080
Audio Input
Microphone
Frequency Response
100 - 11000 Hz
Total Harmonic Distortion (THD)
1%
Audio Output
Speaker(s)
Frequency Response
120 - 14000 Hz
5%
Input Device
Remote control
Network adapter
Wireless
Bluetooth, NFC
1 x USB 2.0 , 1 x video
1 x audio cable - 5 m , 1 x video cable - 5 m , 1 x USB cable - 3 m
Mounting Kit
Included
Power adapter - external
BY0R C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
BY0R C2G 5m USB 2.0 A/B Cable - Black In Stock £5.24
BY0R C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.51
BY0R C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.71
BY0R C2G USB 2.0 To Fast Ethernet Adapter In Stock £22.40
BY0R C2G USB Superbooster Extender Kit In Stock £39.76
Brand: Logitech
Price Range Ex VAT: 750 - 1000
