Easily customize your conference room set-up with GROUP extended cable, a DIN cable. The GROUP extended cable increases the distance from the hub to the camera or speakerphone with a single cable, that can be routed through a conduit for super-clean conference room installations.
- Logitech GROUP - camera extension cable - 10 m
- Cable
- Camera extension cable
- Length
- 10 m
- Connector
- PS/2 - male
- Connector (Second End)
- PS/2 - male
- 2-year warranty
- Cable Type
- Length
- 10 m
- Connector
- 6 pin mini-DIN (PS/2 style) - male
- Included Accessories
- Cable management straps
- FCC Class A certified, RoHS, VW-1
- 278 g
- Limited warranty - 2 years
