Effortless control
Designed specifically for video conferencing systems, this remote control offers seamless operation from up to 8.5 m away, ensuring your meetings go smoothly without the need to approach the system for adjustments. -
Compact and lightweight
With dimensions of 12 cm in width, 1.2 cm in depth, and weighing just 51 g, this remote is designed for comfort and ease of use. Its compact size allows for easy storage and portability, making it an ideal companion for any video conferencing setup. -
Long-lasting battery life
Powered by a CR2032 battery, this remote control is built for longevity, ensuring that you're always in charge of your video conferencing system without frequent battery replacements.
- Logitech video conference system remote control
- Video conference system remote control
- 12 cm x 1.2 cm x 5 cm
- 51 g
- Supported Devices
- Video conferencing system
- Max Operating Distance
- 8.5 m
- Battery
- 1 CR2032
- Designed For
- GROUP HD Video and Audio Conferencing System
- 12 cm
- 1.2 cm
- 5 cm
- 51 g
- Supported Devices
- 8.5 m
- Battery
- 1 CR2032
- Designed For
- Logitech GROUP HD Video and Audio Conferencing System
