Logitech Group - Hub - WW
Quicklinx: CW0WWS00 Mfr#: 993-001136
£18.09 ex VAT
£21.70 inc VAT
GROUP's compact hub simplifies cabling and makes it easy to run cables under tables and through conduit. Integrated data and power means that the camera and speakerphone each connect with a single cable.
Logitech - hub
Hub
3.4 cm x 7.4 cm x 9.4 cm
83 g
Hub
3.4 cm
7.4 cm
9.4 cm
83 g
Brand: Logitech
