Logitech Gaming Mouse G403 HERO - Optical 6 buttons - Wired
Quicklinx: G67LWS00 Mfr#: 910-005633
Type: Mouse
Hurry, only 3 left in stock!
£47.17 ex VAT
£56.60 inc VAT
G403 enters the ring with the next-gen HERO 16K sensor. Get ready for a mouse with next-level 1:1 tracking, 100-16,000 max DPI sensitivity range, and zero smoothing, filtering, or acceleration.
  • HERO 25k Sensor
    Meet the next-generation HERO 25K Sensor, our most advanced sensor ever, with 1:1 tracking, 400+ IPS, and 100-25,600 max DPI sensitivity - plus zero smoothing, filtering, or acceleration
  • LIGHTSYNC RGB
    Game-driven, full-spectrum RGB lighting responds to in-game action, audio, and screen color, synchronizing across G gear. Customize lighting animations and effects from ~16.8M colors using G HUB gaming software, and personalize to match your rig
  • Supreme Comfort and Quality
    G403 is lightweight and comfortably designed to mold to your hand with rubber grips for added control. An optional 10 g removable weight lets you tune the weight to your preferences
  • G HUB
    Configure 6 programmable buttons using Logitech G HUB software to simplify in-game actions. Customize your DPI sensitivity setting from 100 - 25,600 DPI. Choose pixel-precise, low-sens targeting to lightning-fast maneuverability
  • ADVANCED GAMING PERFORMANCE
    With a 1ms response time, G403 is up to 8x faster than standard mice not designed specifically for gaming, delivering near-instantaneous moves and clicks. G403 also features advanced metal-spring button tensioning, keeping the primary left and right mouse buttons poised to trigger with less force. That means exceptional button feel, response, and consistency with every click
Logitech Gaming Mouse G403 HERO - mouse - USB
Mouse
Wired - USB
6.8 cm x 12.4 cm x 4.3 cm
87.3 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
16000 dpi
Performance
1 ms response time, 40 G maximum acceleration, up to 400 inches per second, realtime sensitivity switching 100 - 16000 dpi, report rate: 1000 Hz
Gaming
Rubber side grips, adjustable weight, 6 programmable buttons, ARM 32-bit processor, HERO sensor, true 1:1 tracking, LIGHTSYNC technology, mechanical button tensioning system
Cable Length
2.1 m
Microsoft Windows 7 or later, Apple MacOS 10.11 or later
Mouse
Gaming
6.8 cm
12.4 cm
4.3 cm
87.3 g
Input Device
Wired
USB
Optical
Buttons Qty
6
Movement Resolution
16000 dpi
Performance
Cable Length
2.1 m
1 x USB - 4 pin USB Type A
Weight module (10g.)
Type: Mouse
Brand: Logitech
