Logitech G940 Flight System - Joystick, Pedals & Throttle
Flight System G940
Quicklinx: 64V5WS00 Mfr#: 942-000016
From takeoff to landing, flying with Logitech Flight System G940 makes every aircraft behave and feel like the real thing. Feel wind on your wings. Control engines together or independently. And master tricky maneuvers.
Every piece of Logitech Flight System G940 is carefully crafted with realism in mind. Logitech looked to military and commercial planes and helicopters for inspiration. You get an experience that's more realistic and more fun, with important controls that look, feel, and work just like the real thing.
  • Authentic design
  • Force feedback joystick
    Control your aircraft with confidence. Force feedback effects allow you to feel its movement as well as its reaction to wind shear, buffeting, turbulence, and g-forces.
  • Dual throttle
    Precisely control multi-engine aircraft using the two 8-way hat switches. Or lock the levers when you need to operate your engines in sync.
  • Rudder pedals with toe brakes
    Enjoy true-to-life rudder control, essential when you're performing defensive maneuvers and crosswind landings, or piloting helicopters.
  • Interactive, programmable throttle-base buttons
    Keep in control with buttons that illuminate red, green, amber, or off to indicate the status of critical aircraft systems - gear up, flaps down, and many others - just like they would in a real cockpit.
  • Hard points
    All three components (joystick, throttle, and pedals) can be bolted to a table or other surface for a solid experience.
Logitech Flight System G940 - joystick, pedals and throttle - wired
Joystick, pedals and throttle
Wired
Microsoft Certification
Compatible with Windows 7
Wired
USB
1 x USB
Microsoft Windows Vista / XP
System Requirements Details
Windows XP/Vista - RAM 25 MB
Software Included
I-FORCE force feedback technology
Cable Length
2.4 m
