From takeoff to landing, flying with Logitech Flight System G940 makes every aircraft behave and feel like the real thing. Feel wind on your wings. Control engines together or independently. And master tricky maneuvers.
Every piece of Logitech Flight System G940 is carefully crafted with realism in mind. Logitech looked to military and commercial planes and helicopters for inspiration. You get an experience that's more realistic and more fun, with important controls that look, feel, and work just like the real thing.
Authentic design
Every piece of Logitech Flight System G940 is carefully crafted with realism in mind. Logitech looked to military and commercial planes and helicopters for inspiration. You get an experience that's more realistic and more fun, with important controls that look, feel, and work just like the real thing. -
Force feedback joystick
Control your aircraft with confidence. Force feedback effects allow you to feel its movement as well as its reaction to wind shear, buffeting, turbulence, and g-forces. -
Dual throttle
Precisely control multi-engine aircraft using the two 8-way hat switches. Or lock the levers when you need to operate your engines in sync. -
Rudder pedals with toe brakes
Enjoy true-to-life rudder control, essential when you're performing defensive maneuvers and crosswind landings, or piloting helicopters. -
Interactive, programmable throttle-base buttons
Keep in control with buttons that illuminate red, green, amber, or off to indicate the status of critical aircraft systems - gear up, flaps down, and many others - just like they would in a real cockpit. -
Hard points
All three components (joystick, throttle, and pedals) can be bolted to a table or other surface for a solid experience.
- Logitech Flight System G940 - joystick, pedals and throttle - wired
- Product Type
- Joystick, pedals and throttle
- Connectivity Technology
- Wired
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Wired
- Interface
- USB
- 1 x USB
- OS Required
- Microsoft Windows Vista / XP
- System Requirements Details
- Windows XP/Vista - RAM 25 MB
- Software Included
- I-FORCE force feedback technology
- Cable Length
- 2.4 m
